TCS converter choice
Old Mar 31, 2003 | 02:47 PM
MADCOW's Avatar
Default TCS converter choice
I'm thinking about switching to a TCS converter. I want to get the most out of my car(stock internals). I was thinking ~4000-4400 stall. Would 4400 be too much? What STR should I get? I currently have a Vig2800 w/3.73 gears, Hooker Lt's, 3" True Duals,Maft....etc. I currently run 11.90's @ 115 with a 1.62 60'. What kind of gains could I see with a stall this high? Any suggestions would be appreciated.
Thanks
Mike
<small>[ April 02, 2003, 04:49 PM: Message edited by: MADCOW ]</small>
Old Apr 2, 2003 | 04:54 PM
MADCOW's Avatar
Default Re: TCS converter choice
TTT
Old Apr 2, 2003 | 06:39 PM
Z-Rated's Avatar
Call them and ask for Derek, that boy knows his stuff. He might recomend something smaller.... but im not sure. What about a 3800 2.5 STR? thats what im getting from them. good luck
Drew
Old Apr 2, 2003 | 08:43 PM
Ragtop 99's Avatar
A 4200 will get you into 1.5x 60' range.
You'll need ET Streets or similar rubber; no drag radials for best performance.
Old Apr 3, 2003 | 09:48 AM
CamaroCain's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MADCOW:
<strong> I'm thinking about switching to a TCS converter. I want to get the most out of my car(stock internals). I was thinking ~4000-4400 stall. Would 4400 be too much? What STR should I get? I currently have a Vig2800 w/3.73 gears, Hooker Lt's, 3" True Duals,Maft....etc. I currently run 11.90's @ 115 with a 1.62 60'. What kind of gains could I see with a stall this high? Any suggestions would be appreciated.
Thanks
Mike </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am planning on doing the same as you, trying to get the most out of my car without going into the engine. I am still waiting to see some results though from these TCS converters before I decide to make the switch.
Lynda
Old Apr 3, 2003 | 11:30 AM
Julian's Avatar
Thanks
Mike </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">check these out: http://www.fbodycentral.com/catalog/...hp?cPath=22_47
just to give you another option, since your fairly local. I've only heard good things about these phoenix converters. You can do a search on the www.easternfbody.com forum for phoenix and see for yourself. 3 year warranty and free restall. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 3, 2003 | 09:04 PM
SmithZ's Avatar
MADCOW I have a TCS 4200 and its awesome. I had a ST3600 for about 2years and I believe it to be one of the best street/strip converters there is. My best 60' with the Yank was 1.574 in mid 40 degree weather. And thats with heads and cam with a 4.10 gear. I went to the track this past sunday with the TCS. My first run I cut a 1.566 spinning, a friend said you could see smoke coming from the tires. My second pass, I cut a 1.513, I still dont think I was hoking up that good. My last full pass I did a little longer burnout-stalled it up more and cut a 1.501. I was felling pretty good, so I went to get a 1.4x 60'. My stock rear end couldnt handle it. My car is getting a 12 bolt and a built tranny. I'll let you know more when I get back to the track.
Old Apr 3, 2003 | 09:32 PM
StreetStalkerZ's Avatar
You can't go wrong with TCS on any converter for price,quality and warrenty. I'm part of the test team and im currently testing a 4200 with a 2.7str and will test a 4200 with a 2.5str soon.
Last week i cut several 1.57s and 1.56 spinning the ET Drags on the launch. This converter i have should net some high 1.4 60fts. with some better suspension (which im doing now). Give derek a call and tell him what your wanting and he can hook you up!
Scott
Old Apr 3, 2003 | 11:33 PM
Gold Z's Avatar
Outstanding performance, probably the strongest convertor made for the LS1, three year warranty, unlimited restalls, great tech support and customer service......this is a no brainer. I pulled out a Yank to put in a TCS convertor. A second TCS convertor should be here tomorrow that will go in my son's Camaro.
Old Apr 4, 2003 | 02:48 AM
JB98Z28's Avatar
what is the price range for TCS converters?
Old Apr 4, 2003 | 02:29 PM
MADCOW's Avatar
Thanks for all the replys! Sounds like everyone likes them so far. I'm going to give them a call and see what they say.
Thanks
Mike
