Help with TH400 install
I got a TH400, vigillante stall, tci flexplate and some other stuff from speed inc just recently. I'm in the process of installing the trans, but the tci flexplate it came with a spacer. The instructions from tci say " use it when you are using any tranny other than a 4l60e " .... the sales guy from speed inc on the other hand told me that I don't need to use it because the converter I got is specifically designed for the swap and elimates the need to use it and that would only be needed with a standard th400 converter. What exactly is the point of these spacers, and how do I know for sure if I need to put it in or not? The tranny is bolted up right now and the converter and flexplate line up perfectly as far as the 3 bolts go, but I'm not sure what I should expect to see in the center.
call me anytime.
