trans wont shift into 2nd or Overdrive
Old Jun 8, 2008 | 05:30 AM
84TATURBO408LQ9's Avatar
Default trans wont shift into 2nd or Overdrive
97 model year 4l60e transam,trans wont shift into second,or into overdrive..
the fluids clean,isnt burnt,and doesnt smell.
if you accelerate from a stoplight,first pulls hard,with out any slippage,but it wont shift into second,if you ease off the gas,it shifts directly into third,again,without any slippage.
same thing under normal driving,ease on the gas from a stop,and it will click into 3rd gear,if you romp on it and your doing right at,or a tad under 40 mph,it will downshift into first.
any chance this could be something electrical?
Old Jun 8, 2008 | 07:05 AM
chargedvx6's Avatar
Shift solenoid is my guess. The cheapest easiest fixed prob on a 4L60E
Old Jun 8, 2008 | 07:08 AM
this is common?
Old Jun 8, 2008 | 07:41 AM
chargedvx6's Avatar
On my car it is. I got sick of it all and just had a worked unit fitted. My clutches were fukola, 2nd apply band was glazed as well as the drum being worn from the band dragging. B4 that I changed solenoids to fix some voltage spike issues I had. They are sensitive but luckily the outmost feature of the trans
Old Jun 8, 2008 | 10:23 AM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like the 2-4 band is damaged or badly burned
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 8, 2008 | 07:25 PM
im just gonna convert this turd to a t56..
Old Jun 8, 2008 | 10:02 PM
3rdgentug's Avatar
just build the 4l60e with good parts and a tranny cooler and stall, it will last and be faster then a t56
Old Jun 10, 2008 | 06:41 PM
it finally died last night,lost all forward gears,only has reverse now.
going to call frank tomorrow and get some options,otherwise im going t56.
Old Jun 10, 2008 | 08:28 PM
LS1Tech Sponsor
Sorry feel free to call if you need anything , I am always available till 11 pm eastern time
__________________
Call 888-744-6542
Old Jun 11, 2008 | 12:34 AM
i apreciate it,i need a trans,and like now
my only fear is...whatever happened inside my trans....it made one HELL of a ****** boom when it let go.
Old Jun 11, 2008 | 01:12 AM
LS1Tech Sponsor
Dont worry we dont require a core so we can fix you up
__________________
Call 888-744-6542
