Vig 3600: Is it really that inefficient?
Old Aug 13, 2003 | 10:27 PM
BADFNZ's Avatar
Default Vig 3600: Is it really that inefficient?
I have the opportunity to switch from my Midwest 3500 2.0 to a Vig 3600 for under $200. My Midwest is a good, streetable converter, but my best 60' to date is a crappy 1.84 on Nittos. I hear people easily pulling 1.7's and some 1.6's on Nittos w/ the Vig and even better on ET Streets.
My concern is the inefficiency. Since I have over 400rwhp, surprising a modded 03 Cobra from a roll is fun to me But I'm afraid that if I switch to the Vig, some of that fun will end. I don't want to lose mph or my ability to suprise people on the highway.
I know people will tell me to go for a TP4000+ but that's not an option right now. I heard about the flatline Vig's show on the dyno from 4k-5k rpm and this worries me. Can someone make me feel better here?
Old Aug 14, 2003 | 07:42 AM
98TAauto's Avatar
Default Re: Vig 3600: Is it really that inefficient?
i pulled a 1.58 on 16inch nittos with the vig3600 and bolt ons. Cam only I could only pull a 1.64 best spining on nittos.
she trapped 113 bolt on and 117 cam only so thats right there with the yanks and others out there. It may loose a little on top end, but it gets ya off the line. Thats where it counts
Old Aug 14, 2003 | 08:05 AM
Patrick G's Avatar
LS1 Tech Administrator
The Midwest converter uses many of the same internal components as the Vig. You shouldn't lose that much efficiency. If you really like racing from a roll though, a switch to a Yank Pro Thruster 4400 might be worth waiting for.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 14, 2003 | 11:00 AM
BADFNZ's Avatar
I spent 2 hours last night reading Vig 3600 threads from up to a year and a half ago. I saw that you have owned pretty much every converter under the sun
Can you be more specific as to what similar components both Midwest and PI use? If I won't lose much efficiency, then this $200 swap is a no brainer
Old Aug 14, 2003 | 11:05 AM
BADFNZ's Avatar
Since you said Midwest and PI use the same internals, I went back and looked closely at my graph, and sure enough, there's the flat line from about 4500-5300!
Old Aug 14, 2003 | 01:42 PM
Patrick G's Avatar
Most converter companies use the venerable 082 stator for their high stall torque converters. Precision does, TCI does, and I believe Midwest does too. This stator gives excellent throttle response, high STR, but less than average efficiency. Yank uses stators that have strong launch capabilities and very good efficiency. The way a converter company works the blade angles of the pump and its clearances with the turbine also heavily determine efficiency. PI is no better or worse than Midwest in this regard so I would expect the efficiencies to be in the same ballpark. Yes, $200 upgrade should be a no-brainer. Have fun!
__________________
Old Aug 14, 2003 | 04:56 PM
2001 White Ws6's Avatar
Hey LS1blackz28, tell me how did the Midwest 3500 2.0 TC feel? I'm gonna go with a Midwest 3400 2.0 TC Also did you install it yourself or where did you take it to be installed? Will i lose any top end with the midwest 3400 2.0 TC compared with the stock TC? Thanks
Old Aug 14, 2003 | 05:33 PM
BADFNZ's Avatar
It feels damn good. So damn good I'm not sure I wanna give it up quite yet. I've never put ET streets on it so I kind of want to see what it'll do before I give it up. Before the TC I was trapping 109 in the middle of winter, and after the TC I was trapping 107 in 70 degree weather. So I don't think my top end was effected much.
Still wanna run for $50?
Old Aug 14, 2003 | 09:14 PM
Dude you'll hand my *** to me. Figured you know who i was and you basically have the same TC i'm gonna get. So did you install it yourself or take it somewhere to be installed??
Old Aug 15, 2003 | 02:03 PM
BADFNZ's Avatar
JC did it for me for $130
