build 4l60e what tRANNI fLUID IS BETTER TO RUN ?
Castrol ? Atf
ok .. im Using Castrol Domestic Multi-Purpose ATF " which says on CASTROL's website Meets DEXRON®–III H requirements. Also satisfies requirements of DEXRON®, DEXRON®–III, IIE, and II. Do not use this ATF in applications calling for DEXRON®–VI.
So does that mean this Castrol ATF will be good for my 402 , A4 , 4L60E built Transmission ? any help is appriciated
transmission Fluid weight ?
What is the Oil Weight of Tranmission Fluid ? Mostly anyways , like oil it like 5 weight when its cold and 30 weight when its hott , what it the weight of transmission fluid ? or the velosity of it ? does anyone have a clue , cause i know its pretty thin. almost like water .. well not that thin but you know what i mean ..
Im using Castrol Dexron III , but the name has now changed to Castrol Domestic Multi-Purpose ATF Fluid .
