SS4000 Vs. SS3600 "for a custom cam+N2O"
its cam only "231/240 .643/.608 112+4" predator-z speced, full bolt ons and 3.73 gear on 295 R18" NA with 100 wet juice " in case" from time to time
Its a street racing car, im gonna rebuilt the tranny soon and cant decide what stall speed to go with?!
can you help me deciding which one is better for my mods
Thanx in advance.
99Hawk262
Funny thing about how converters act way different, in different combos....My extension is 5850 rpm with 6600 shift points, and has one hell of a flash. So far, for my combo (with that high flash and big extension) it's the best roll racing converter I've had in thier. I know on yours it was a little to tight upstairs.
another believer look at times for both stalls...yeah i had both
For the bottle I would recommend the SS3600 its a little tighter and will MPH better then the 4000 you can hit it hard outta the hole to make up for the stall speed.
If you plan on only a 100 hit then the SS4000 should be good but if your going to grow ( you will I promise) Go with the SS3600.
YANK -FTMFW!
btw, your car is amazing, probably the fastest boltons i ever seen
I Had both the SS3600 and the SS4000 with my 370 Nitrous setup. N/A the SS4000 was the converter of choice hands down. With the SS3600 I couldn't sixty as hard as I wanted to off the bottle but I could sixty wherever I wanted to on the bottle depending on how hard I brought the nitrous in.
If your looking for on the bottle performance use the 3600 if its N/A your after go SS4000.
Eaither way I am sure you will be happy they are both very nice converters.
