Tranny and Differential Fluid...which Fluid?
Old Aug 14, 2003 | 08:32 PM
OfficerZ28's Avatar
Default Tranny and Differential Fluid...which Fluid?
Time to change my fluids....just wanted to confirm which fluids to use for my AUTOMATIC tranny and 2.73 differential...??? Thanks guys
Old Aug 14, 2003 | 08:41 PM
99taws6's Avatar
Default Re: Tranny and Differential Fluid...which Fluid?
Tranny = Dexron III
Rearend = Gear oil (80 or 90w not sure) + 1 tube of limited slip additive
Old Aug 14, 2003 | 08:43 PM
jeffrey G's Avatar
heres a ttt for ya, im interested in some second opinions.
Old Aug 16, 2003 | 11:34 AM
Jorday's Avatar
axle- redline 80W-90 or royal purple 75W-150. FWIW, the royal purple thick stuff reduced the gear noise a bit in my other M6 car.
Transmission- valvoline dexron III in the stock transmission, motorcraft type F in the Yank tranny. (He specifically said to use that so I did.)
Jordan
Old Aug 16, 2003 | 03:00 PM
Ragtop 99's Avatar
GM calls for synthetic fluid in the rear axle + 1 bottle additive.
Normal Dexron III in the tranny is fine. Rather than buy expensive oils, change the fluid more often.
Old Aug 16, 2003 | 09:00 PM
Cheatin' Chad's Avatar
I use:
Differential:Redline 75-90
BTW it already has the limited slip friction modifier.
Transmission:Redline D4 ATF
