TH400 Guys Need Help
Old Aug 15, 2003 | 08:20 PM
Vengeance Racing's Avatar
LS1TECH Sponsor
Default TH400 Guys Need Help
Hey guys I am building a car from the ground up I have everything except when I went to bolt up my TH400 with my Yank Brace it will not fit. The car was originally a LT1 but now is convertered to run LS1 everthing but the brace will not fit the floor. I know BMR makes a brace but with no TQ Arm mount. I call Mike at Yank today but no response yet I call someone else (who will remain nameless --Allan-- ) but no call back. Does anyone make a TH400 brace with a TQarm mount built in to work with a LT1 floor. Thanks I need to overnight this thing to finish the car ASAP>>
Old Aug 16, 2003 | 08:02 AM
99taws6's Avatar
Default Re: TH400 Guys Need Help
What is the difference between the LT1 and LS1 braces? I thought they were the same?
Old Aug 16, 2003 | 07:09 PM
LS1TECH Sponsor
So did I that is why I bought the Yank TH400 brace I had two cars on the rack and I went back on forth. It fit a 2002 just fine but my 93 would not work anybody else have a idea of what to do besides make one from scratch.
Old Aug 21, 2003 | 10:50 AM
Black Sunshine/ 00SS's Avatar
Try checking with Steve Spohn.
Old Aug 21, 2003 | 04:42 PM
95LS1TA's Avatar
The LT1 bodies are different than the ls1 bodies????? I had the same problem in my LS1 conversion. I bought a LS1 A4 brace and it wouldn't mount to the body. Than I tried using the stock LT1 A4 brace and the ls1 4l60e trany mount sits farther back than the LT1 about 2 inches so I made the holes larger on my stock LT1 brace and it worked barely. So the bodies are different and the tarny mount sits in a different spot. So it will probably have to be custom.
Old Aug 21, 2003 | 05:42 PM
turbo's Avatar
Same problem here, I just did the same as 95LS1TA did, just make the holes bigger in the brace, worked fine for me.
Casey
Old Aug 21, 2003 | 05:53 PM
AndUAndI's Avatar
Yes, like turbo said, they are different. Had mine fabricated to match body holes on my 1994 chassis and the 4L60E off the LS1.
Old Aug 21, 2003 | 06:57 PM
Doc's Avatar
Doc
www.transmissioncenter.net th400 conversion kit
