Vig converter, Lock-up or non ? Ways to tell ?
Old Aug 16, 2003 | 11:30 PM
J 98ta's Avatar
Default Vig converter, Lock-up or non ? Ways to tell ?
If the converter is out of car, is there physical ways to tell the difference ? I am looking at buying a used one, and want to be sure it is a lock-up version. Seller is not 100% sure it is lock-up. It was bought from thunder racing. I talked to them on the phone today and they told me that unless specifically ordered as non-lockup, it would probably be lockup. Any physical way to tell for sure ?
Thanks !
'J
Old Aug 20, 2003 | 03:54 PM
GreekZ's Avatar
Default Re: Vig converter, Lock-up or non ? Ways to tell ?
They look the same but my non-lockup converter
is lighter (about 10lbs) than the lock-up version
Old Aug 20, 2003 | 03:57 PM
GreekZ's Avatar
BTW, a non-lockup converter will not work in a
stock 4L60E.
Old Aug 22, 2003 | 12:41 PM
J 98ta's Avatar
Thanks GreekZ,
Would the tranny have to be completely rebuilt ? The guy has a shift kit (trans-go i believe) installed. I am 99% sure it would be a lock-up version, but just wanted to check for sure. Thanks for the help.
'J
Old Aug 22, 2003 | 01:46 PM
GreekZ's Avatar
Thanks GreekZ,
'J
I believe just the valve body needs to be modified. If all
he did was install trans-go then it's a lock-up converter.
I remember my Vig lock-up converter weighed 36lbs and the
non-lockup was around 27lbs
