Non-computer controlled trannys...disadvantages/drawbacks?
I was never a big fan of computer controlled transmissions in a performance car. On my mom and dads Cadillac...great. But not on high horsepower application.
1. Cant change shift points through PCM (must do it with weights internally)....
Well...I thought that I had a few in mind when I first started to make this thread...if any of you can add on to the list, please do so. I know that some of you may prefer a computer-controlled tranny and some of you dont. To those that dont..probably can point out some bad things about it. Anyhow, if you want, you can list the advantages/pluses about 'em. There may be a few that I dont already know about. Thanks
less likely to break
you can change the shift points to anything you want anytime you want because you are the shifter.
disadvantage:
harder to be consistent because your reactions introduce a another variable.
you need a shift light or more accurate tach if you shift above ~6300 rpm
line pressure is frequently 100% even when you are just tooling around, so your shifts will be extra firm or hard (you may be able to avoid this with vacuuum modulation)
