Trans range switch problem, DTC P0706
Old Jun 25, 2008 | 10:07 AM
Ram Air IV's Avatar
Default Trans range switch problem, DTC P0706
I got a DTC, P0706 from my 4L60E (LQ9 engine) but i don´t know what it means. I Have checked the lower switch on the left side of the transmisson house.
P=776 connected with 771
R=776 con. 771 + 772
N=771 con. 772
D=776 con. 772
3=772 con. 773
2=776 con. 771 + 772 + 773
1=same as above
Is this correct ? Anyone know what is wrong / Magnus
Old Jun 25, 2008 | 12:15 PM
69LT1Bird's Avatar
Have you checked the adjustment?
Conditions for Setting DTC
Condition 1
The PCM detects DRIVE or REVERSE at vehicle start-up.
Condition 2
The PCM detects PARK or NEUTRAL and the following conditions occur for 10 seconds:
• The throttle position (TP) is 5 percent or greater.
• Engine torque is greater than 68 N·m (50 lb ft).
• The vehicle speed is 32 km/h (20 mph) or greater.
