Can I install a Trans Go myself ?
Old Apr 10, 2003 | 10:40 PM
DMcRacer's Avatar
Default Can I install a Trans Go myself ?
Does the tranny have to come out of the car to do it ?
Old Apr 10, 2003 | 11:27 PM
red jet's Avatar
Default Re: Can I install a Trans Go myself ?
no the tranny stays on the car. Just drain the fluid and removed the pan and if you can get help it wont hurt and make sure you follow the instuction. It's not brain surgury, but not easy either if doing on the floor it's messy expect trans fluid running down your arm to your chest. Good luck and take your time and double check everything.
