4l60e gone bad???
99 camaro z28 4l60e w/ 103,000mi- car is bone stock no aftermarket parts what so ever
checked fluid- full, recent filter change
Most dealerships have a 1 month 1000 mile on the car.
BTW filter change is a waste of money, if your gonna change the filter do a flush at the same time, its like me draining two quarts of engine oil changing the oil filter and topping it off and saying I did an oil change.
thats how we get most of our tranny work.
its waste of time to JUST change the filter, like I stated with my oil change scenario its the same thing, doing a tranny flush is maintenance on most cars (except BMWs and others) every 50k you should do a flush, I was suggesting a cheap alternative, if it works great if not its no big deal, then you know you need a tranny that way you dont have to pay for a diagnosis, probably cost about the same or less for a flush, if he does it himself
If I take out a radiator hose I am not draining all the coolant out of it unless I run it till its clean, its the same concept.
To me its worth a try and if you dont want to thats fine too, and yes the 4l60e suck *** thats just one more reason why I did the a4 to m6 swap.
In your case I may be your tranny is bad but to me its worth a try if you know how to do a flush, just my two cents.
Good luck man hopefully it something cheap!I wouldnt get your hopes up tho, now you have an excuse to build it if all else fails.
with your car over 100k miles, i think its time to get a brand new beefed up tranny.
