4L80E in fbody WITHOUT BFH to tunnel
Old Sep 19, 2008 | 08:26 PM
DeepV's Avatar
awesome, thanks.
Old Sep 20, 2008 | 10:22 PM
ShevrolayZ28's Avatar
Originally Posted by performabuilt
Give me a few days and I will come up with a solution
Any luck? I haven't heard from Rossler and I'm ready to say the hell with it and bang it out....with my noggin
FWIW I made a custom fitting for the rear cooler line so that I don't have to dent the other side. What I did was drill out a brass 1/4" pipe thread 90 with a "u" sized drill bit and then pressed a piece of 3/8" steel tubing into it. (I stole that idea from Vince@FLT lol.)
Old Sep 20, 2008 | 11:13 PM
FLT's Avatar
FLT
FWIW I made a custom fitting for the rear cooler line so that I don't have to dent the other side. What I did was drill out a brass 1/4" pipe thread 90 with a "u" sized drill bit and then pressed a piece of 3/8" steel tubing into it. (I stole that idea from Frank@FLT lol.)
Frank who???????? There is nobody by the name of Frank here. I think you forgot who told you about that. Vince
Old Sep 20, 2008 | 11:30 PM
lol It was you, Vince .....at least I got the company right
Sorry 'bout that!
Old Sep 21, 2008 | 12:06 AM
FLT's Avatar
FLT
AAAAHHHHHHH thats better!
Old Aug 13, 2009 | 03:06 AM
Avengeance's Avatar
Bringing this back up.... simple solution I thought of... what about just making or coming up with a 90* harness plug instead of the straight?
I just finished hacking up my tunnel to make this 80E plug work and while I was cursing the whole time I wondered why someone cant just make a 90* style harness plug... then the most that would be needed would be needed would be a slight BFH to the tunnel instead of cutting.
Old Aug 13, 2009 | 09:13 AM
FrankSS's Avatar
saving this for my swap... thanks for the links
Old Aug 13, 2009 | 11:10 AM
Bad30th's Avatar
Subscribing...
Rob (Bad30th)
Old Aug 14, 2009 | 05:22 PM
theblur98ss's Avatar
AFter dropping my tranny 3 times and cutting more of the tunnel out I said the hell with it. I went inside the car and took a hole saw and just cut out a circle and ran my harness from inside straight into the plug. I'm not sure if this is possible with the stock harness or not. I'm using BS3 to control mine so it was no biggy.
Old Aug 14, 2009 | 07:22 PM
Firechikn's Avatar
I'd be surprised if someone doesn't make a 90 plug. The plug on my allison/demax, is 90, and looks the same as the 4l80. Maybe you could buy an external plug for the allison and splice it to your harness.
Old Aug 16, 2009 | 09:20 AM
tals7's Avatar
Smile
i have tci controler and it has 90degre plug in.no smashing just cut small window in pan susport(make sure it leaves room for plug to move up).all in all not a big deal.
Old Aug 16, 2009 | 04:24 PM
  #32
FrankSS's Avatar
hey tals7 u have a pic of what urs is like?
Old Aug 16, 2009 | 05:43 PM
  #33
tals7's Avatar
i do i have many i would share but i dont know to get them on ls1tech.ihave many photos of swap and the ones people ask about.i replaced my 4l60e with gearstar level 4 4l85e with tci tcu.work awsome i can control everything.there is no smashing with bfh at all just three cuts to make .
Old Aug 17, 2009 | 02:45 AM
  #34
Avengeance's Avatar
email me the pics and I will host them for you.
