4L80E in fbody WITHOUT BFH to tunnel
Old Jul 14, 2008 | 12:55 PM
ShevrolayZ28's Avatar
Default 4L80E in fbody WITHOUT BFH to tunnel
Why can't we move the main electrical plug to the pan? Has anyone tried this? Is the internal harness not long enough?
Old Jul 14, 2008 | 06:21 PM
formula17's Avatar
Wondered and asked this same question, but no responses. Maybe you'll get some.
Old Jul 14, 2008 | 08:19 PM
jimmyblue's Avatar
Moderator
I would think putting the connector "below the water line" is
not a great idea. But what about extending the harness inside,
and making a seal-block for a smaller wire bundle to come out
in the original plug location, maybe at the point furthest from
the tunnel sheet metal?
Old Jul 14, 2008 | 08:36 PM
QuietSS's Avatar
subscribing!!!
Great question guys
Old Jul 14, 2008 | 11:51 PM
I briefly spoke with Carl Rossler about the clearance problem. We discussed moving the plug to the pan. I think he said he would check to see if the harness length allows relocation, and if it did, he could check with Moroso for a custom pan.
We also discussed moving the connector inside the trani but he didn't seem too enthused. (I'm not sure why, maybe there isn't room inside.) But if only a bundle of wires came out the side, it would most likely be enough clearance to avoid BFHing the tunnel.
....What kind of material would "permanently" fill in around the wires? Maybe a big wad of epoxy?
Old Sep 3, 2008 | 11:57 AM
I'm still on this. Carl has been very busy but he said he'd look into it and call me back. Stay tuned....
Old Sep 4, 2008 | 08:47 AM
DeepV's Avatar
subscribed.
Old Sep 4, 2008 | 09:24 AM
dlove's Avatar
why cant you just hammer the tunnel? it is only an fbody. you would spend a ton of time and money relocating the wires.
Old Sep 4, 2008 | 09:43 AM
performabuilt's Avatar
LS1Tech Sponsor
Give me a few days and I will come up with a solution
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 4, 2008 | 09:55 AM
Darren P's Avatar
A hammer is for ****** I just used a saw
Old Sep 4, 2008 | 10:36 AM
dlove's Avatar
angle grinder (with cutoff wheel) > saw
Old Sep 4, 2008 | 10:51 AM
Zombie's Avatar
Plasma cutter > *
Old Sep 4, 2008 | 11:08 AM
A real man would use a shape charge. BOOM! All done.
Seriously, I figure if there's a way to gain some slack in the harness so that the plug can reach the just below in the pan, a bulkhead could be installed in the pan by Moroso or somebody and we'd be all set. Not a lot of work...just a custom pan.
I'm really not freaking out over this. My car is all marked up and ready for the hammer/cutting/welding. I just thought if there's a simple, clean solution, why not?
Frank, thanks for looking into this.
Old Sep 4, 2008 | 03:49 PM
Darren P's Avatar
Dewalt sawzall>any kind of cutoff wheel
Old Sep 6, 2008 | 07:13 PM
jwastedx's Avatar
Any more info on this yet?
Old Sep 7, 2008 | 11:30 AM
Nothing new on my end. Though I did have a very brief conversation about it with the Moroso guy yesterday at the track.
Ima give it another week before I start chopping and banging....
Old Sep 7, 2008 | 11:34 AM
GrahamHill's Avatar
Speaking of harness... what wires in a 99 pcm need to be swapped around from an 02 80E pigtail?
Old Sep 8, 2008 | 08:40 PM
DeepV's Avatar
take some pics of the cutting please, I'm looking at doing the swap soon and would appreciate it.
Old Sep 8, 2008 | 11:25 PM
https://ls1tech.com/forums/showthrea...hlight=fitting
https://ls1tech.com/forums/showthrea...=748119&page=3
http://www.sloppymechanics.com/archi...allations.html
http://richmondperformancemusclecars...9.aspx?ppage=1
Old Sep 19, 2008 | 07:50 PM
Stupid Boost's Avatar
Default .....
I have a 4l80 and the plug is where the vacuum modulator is on a turbo 400 and it came that way in a jaguar.
