Stock converter problems on built Trans
Old Aug 24, 2003 | 12:04 AM
dissonance's Avatar
Default Stock converter problems on built Trans
I just rebuilt my 1st 4l60e and everything went great but I’m having problem with my stock rebuilt converter. I have no lockup from what I can tell. What do I need to look at 1st?
the Trans died due to the sun shell braking, something else I may have mixed up the springs that are in the pump , converter lockup and boost valve but I replaced the boost valve with an upgrade. It would be great if someone had pictures of the springs in the pump and order…
Old Aug 27, 2003 | 09:05 AM
dissonance's Avatar
Default Re: Stock converter problems on built Trans
If the converter was not locking up would I get a code right away? Also the converter feels like another shift right? Small drop in rpm's? My old converter would pull the rpm's down 300 or so. I can’t tell an rpm drop in 4th with the new converter? Do new ones lockup better and aren’t as noticeable?
