View Poll Results: t56 or built th400?
T56... *have fun changing clutches sucker!*
5
26.32%
th400...*wahhh my car sucks on the highway *
14
73.68%
Voters: 19. You may not vote on this poll
i NEED your guys' opinion.. have a chance to swap t56->th400
Old 11-06-2008, 09:10 PM
TurboAv's Avatar
As long as you aren't going a speed that's going to over rev the motor then drop it into 2nd and hammer it.
Old 11-06-2008, 09:44 PM
Detoxx03's Avatar
My cousin has a th400 on his camaro and that ^ is what he usually does.
Old 11-06-2008, 10:35 PM
exodus's Avatar
yeah, depends on speed and gearing like mentioned before
Old 11-07-2008, 11:09 PM
trans2000am's Avatar
make sure you give it gas when your downshifting or you can blow it up.
Old 11-11-2008, 11:08 PM
7420NW7TH's Avatar
That basically what I did. Went from T56 to TH400. I still like t56 for normal street driving and somewhat spirited driving, but I really don't regret going TH400.
The wheels up launchs >>> rowing gears. And replacing clutches gets old fast...
And who needs overdrive, it just means you'll spend more money in gas. Which do you want to do, spend money on gas, or money on clutches?
Old 11-14-2008, 02:50 PM
sidewayz28's Avatar
whats your setup? what kinda gears do you run? Im still using stock 3.42s
Old 11-14-2008, 02:51 PM
sidewayz28's Avatar
can you explain?
Old 11-17-2008, 03:33 PM
Mike96z's Avatar
Im also curious on this topic, wanting to do this myself. sidewayz28 what size stall are you using and what are your RPM's on the highway etc?
Old 11-17-2008, 06:03 PM
sidewayz28's Avatar
i dont have the exact specs on the stall. but its a 10" rebuilt Yank, and i was told its a 3400+
my rpms are JUST shy of 3k at 60mph with 3.42 gears
Old 11-17-2008, 06:31 PM
Mike96z's Avatar
LS1? Thats alittle too high for me, I still wanna be able to get up to 100mph without blowin my **** up.
Old 11-18-2008, 12:29 AM
sidewayz28's Avatar
yes, ls1. High way driving is completely different w/ the th400.. sucks compared to T56. My car isn't my daily, and i would have never swapped if it was. I havent really felt 1st gear with the th400 yet cause im on shitty sumitomo 315s.
Old 11-18-2008, 07:42 AM
  #32
DannoWS6's Avatar
Unless you have another car to drive or the Camaro is gonna be raced at the track a lot I wouldn't get an A3.
I'd do a 4l80E swap before I did a TH400/350. I'd stick with the T56 until you smoke it. Unless you go to the track like every weekend or something.
With 3.91's and an A4 w/ 26" tires that's as aggressive as I am willing to go (2500 @ 70mph). I couldn't even imagine not having OD and ever driving that setup on the hwy.
Th400 w/ no lockup, you would probably be spinning at 3300-3400 at 65 with 3.42's.
T56 with the right clutch can take a H/C car with up to 150 shot. Like said earlier though it will lack consistency.
