Another which converter to get post...
Old Jul 20, 2008 | 07:31 AM
Anan A.'s Avatar
Default Another which converter to get post...
So I'm in the market for a converter for my '98 z28... From what I've read everyone goes with Yank and Vigilante converters...
My car is a heads/cam setup with stock 3.23's but I plan on going 3.73 once funds pick up along with picking up the new converter.
This is my daily driver so I was thinking of a Yank3600 since I don't want too much for the daily drivability, but I want enough for the track
I have a stock trans and I plan on putting a B&M Supercooler to keep it running at optimal temps so it doesn't overheat if I get stuck in traffic...
What are you guys opinions. I'm thinking a Yank3600 with 3.73's would work well enough for a daily driven street/strip car.
Opinions, complaints, different ideas?
Old Jul 20, 2008 | 07:34 AM
LT1-DAN's Avatar
I have a Vig 3200, and all I can say is it kicks ***!!! I am very very happy with the performance with it.
Old Jul 20, 2008 | 10:19 AM
Yank's Avatar
Give us a call on Monday at 775 826 9955
so we can help with your ?
Old Jul 20, 2008 | 07:46 PM
kdavis's Avatar
Check with circle d. Great converters.
Old Jul 20, 2008 | 08:28 PM
TXZ28LS1's Avatar
happy with my vig 3200 stall as well!!!!!!!!!!!!!
Old Jul 20, 2008 | 08:36 PM
Anan A.'s Avatar
Yes I've heard the Vig's were very good converters as well... I heard they are a little underrated so the 3200 is a little higher than advertised?
This is a daily driver car and I do run people from both digs and rolls (yes fail but some people can't drive or don't want to self destruct their 10 bolts) and I go to the 1/8th mile track a couple times a month and maybe the 1/4 once a month or so...
I need a good street/strip setup is what I'm saying.
So far I'm looking at the Yank and the Vig.
Old Jul 20, 2008 | 09:45 PM
kdavis's Avatar
You may also want to check into circle d aswell. You will not be disappointed. Call Chris 7138958834.
Old Jul 20, 2008 | 10:59 PM
jsteele90's Avatar
vig 3600 here and i love it
Old Jul 20, 2008 | 11:25 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Please don't cut corners in this area.
Call Chris at Circle D and you'll never look back.
You will thank me later. It's the best mod for the $$$, but going with a quality unit will save you a ton of time and $$$
Been there and done that.
I say that because they have continously proven themselves and I pulled 1.37 60fts with an extremely tight streetable 4500 Circle D converter this weekend in +2200 DA air.
It just doesn't get any better IMHO.
Old Jul 21, 2008 | 04:52 AM
Anan A.'s Avatar
I will definitely give him a call and see what he says...
Any more ideas?
I think I'm going to go with a lower stall, more like around 3200 or so... I need to figure out the rest of my setup at the moment.
Old Jul 21, 2008 | 06:54 AM
Z-RATED94's Avatar
If it's a Vig. then maybe a 3200, they are slightly under rated. Don't get one that has to low of a stall. You'll kick yourself in the *** later. I could of gone bigger than the SS3600 if I didn't plan on spraying a little under the stall rating to help raise it.
Old Jul 21, 2008 | 08:20 AM
Circle-D's Avatar
Any more ideas?
Looking forward to the call. 2 recommendations for you so far.
"2C"- 3200-3400 = Great street manors, good at track
"4C" -3600-3800 = Great at the track, good street manors
Depends on which way you want to go. Talk to you soon.
Chris
Old Jul 23, 2008 | 05:52 PM
ybaslo1's Avatar
Do it once. Yank SS4000, cooler, deeper trans pan, and TCI flexplate.
Old Jul 23, 2008 | 09:33 PM
JFM-jr's Avatar
Circle D gets my vote. GREAT customer service from Chris
Old Jul 23, 2008 | 11:41 PM
chevyz2801's Avatar
i got a py3400 and love it but i would get a higher stall next time
Old Jul 24, 2008 | 02:35 AM
99Hawk262's Avatar
You need a Yank PT4000....4400 might be a little bigger than what you're wanting. The PT converters hit hard as hell off the line and pull like there's no tomorrow on the top-end. I had an SS4000 before this and it was a great street converter, but didn't come close to the PT on the top-end. The PT will be the last converter you'll ever want. Plus, don't forget Yanks full 3-year replacement warranty. Can't beat it. This PT 4400 is my third converter, and it's the baddest by far.
Old Jul 24, 2008 | 11:05 AM
00_Z-28's Avatar
I run an EDGE 3200 its not the most popular converter on this site but its a great reliable converter. There a little bit cheeper than yank and vig. Also it comes with a one year warenty so if you decide you dont like it just send it back no questions asked. Call uhm up and talk to andrea. He will answer all your questions and build a converter to your specs.
Old Jul 24, 2008 | 11:50 AM
ShevrolayZ28's Avatar
Might he be better off with the SS converter for DD use? I don't have much experience with performance converters but Yank recommended the SS 4000 for my HC car that I use weekends. If I DD'd the car the recommendation would have been more likely the SS3200 or 3600.
Old Jul 24, 2008 | 04:24 PM
TORK?'s Avatar
Yank ss3800 around town with 3.73 is fun
Old Jul 24, 2008 | 04:59 PM
2002SS#1811's Avatar
Had a SS3600 for about a year and loved it...Stepping up to a YANK SS4000 Since I had H/C installed. Putting out 471 hp and 406 TQ to the ground now. The 4000 should not be so tight as the 3600 is now. Good Luck!!!
