Park to Drive problem
Old Aug 25, 2003 | 12:08 AM
Gev's Avatar
Gev
Default Park to Drive problem
I recently installed the TCI shift kit p/n# 376002.
Install was very easy. Took it off the stands and put in reverse, quicker and sort of moved the car when going into reverse. Then wehn I put it into drive, car jerks rather harshly going into drive. Shifts are fine though. The jerk mellows out a little after it heats up to normal temps, but when it's cold it really jerks hard.
Anyone having these problems or can suggest anything?
Old Aug 25, 2003 | 07:29 AM
Kevin Steele's Avatar
Default Re: Park to Drive problem
That is very normal with the TCI Trans-Scat kit. I hope you like the kit. If you have any more questions you can call 1-662-224-8972.
Kevin Steele
TCI
Product Engineer
Old Aug 25, 2003 | 10:25 AM
Gev's Avatar
Gev
Once again, TCI's customer service is top notch.
