any lenco vendors out there?
The Bruno is basically a front part of a transmission, just there so you can use a torque converter. It uses a pump to circulate the fluid in and out of the converter and a output shaft that goes to the regular Lenco unit. You can also get a Lenco that will take a torque converter I think they call it the Lencodrive.
Hope that helps.
Chris
Hope that helps.
Chris
