Still Fighting Tranny Issues....help Please
here is the verdict....
the car was running 10.80s on a 100 shot for the first 2 shakedown passes....than BAM the rear end goes. i figure while the rear is out ill get a built tranny. well the rear goes in and the only problem is my MPH is off about 6%? going from 3.55s to 3.31s.
anyways, the tranny goes in and now the tranny never wants to shift. the GM tech II scanner shows the car going the 20MPH when im going almost 70. as you know LS1s shifts are based on MPH at % throttle....(this is all on the same tuning. nothing should have changed!)
so now i have replaced the speed sensor and relucant wheel. SAME mph reading and tranny doesnt want to shift out of 1st unless you get up to about 6000 and then let off it will upshift.
so........can anyone give me direction on what to try next? we have found a way around this in the tune but i want things RIGHT. please give me a hand on what to try or if there is something possibly wrong with the tranny!
thanks, adam
P.S. I'm not a tuner, so I could be wrong. I just remember changing a few things back when I had LS1Edit v 1.21 (old) and there being a table that controled rpm vs. tps like you talked about for shift, but also (digging deep in the memories) a RPM vs Speed -->REV LIMITER<-- table that you might check out as just an idea. Again, just an idea and I am not a tuner whatsoever.
P.P.S. Good luck, I know how frustrating these things can be.
Is the tps working right? did you change the stall speed?
What trans did you have and what did you replace it with? I know '00 camaro but whats the new trans?
Why did you replace the reluctor wheel, visual check should be good was it damaged? Does the new one fit tight?
what are ways in testing my tps sensor? i would assume its all working fine as nothing has been touched except the tranny. the old sensor and reluctor wheel looked fine so maybe it could be something with the tps.
What I do is hook up HPTuners with the engine off, scanner/key on press the gas pedal down.
The speed sensor is connected to the output shaft, thats connected to the driveshaft. If nothing was changed except the trans and rear thats a short piece of the car to look for problems in. From the reluctor wheel back to the axles. This is if you insist that nothing else is wrong because nothing else has been messed with. Obviously something is wrong if the speedo is reading wrong, so you either have a different gear ratio than you think or the speed sensor is messed up, wrong tooth count on the reluctor wheel, I don't know.
You say you found a way around it by tuning, what did you do?
since im running an autometer speed i can recalibrate the cluster to read the correct mph which only leads in having a funky tune.
this is what i have found the 4l60e relector wheel is supposed to look like......
Here is a picture of one I have here on the Dyno. I think yours is wrong. I have never seen one like the one you have in the picture above. John is correct that it should have 40 tooth rotor. In my book there is only one listing and that is all I have ever installed. Picture below is what you should have.
Also it looks like the threads are damaged in your pic. You might want to fix those as well.
hopefully it wont be to bad of an install. from reading into it, it looks like the gear will have to be pressed on.
