Quick Question ???
Old Aug 9, 2008 | 10:28 AM
fbirdserge00's Avatar
Default Quick Question ???
Why is it when iget on the freeway once im going about 70 i feel the car kick down a gear and (I guess from O/D to 4th), but it only does it sometimes
Old Aug 9, 2008 | 11:20 AM
FLT's Avatar
FLT
It sounds like what you are talking about is lockup. You should have 1ST,2ND,3RD,4Th and then lockup. Lock up is the torque converter clutch engages. If you have a condition when it going in and out, you might have a condition where you could many different problems. Engine misfires, worn valve body, damaged converter clutch, and there are many different possibilities. In some cases a simple tune might correct this issue as well. Vince
Old Aug 9, 2008 | 07:52 PM
thanks i am throwing a p0300 random misfire code , but i dont know y its misfiring and it sure dont feel like it is. i just did a complete tune up and made sure everything was well secured
Old Aug 9, 2008 | 08:18 PM
performabuilt's Avatar
LS1Tech Sponsor
The random missfire code is certainly why lockup goes out and in the PCM will disable lockup if it sees missfire
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 10, 2008 | 12:22 AM
ne1 know how i might be able to get rid of the misfire?it will be appreciated.
Old Aug 10, 2008 | 05:04 AM
FLT's Avatar
FLT
You could have a tune done and have the misfire tables raised I believe. I would contact one and also have them look your car over to see if they see anything as well. Vince
