questions on shiftkits and things
Old Aug 9, 2008 | 09:37 PM
LS1nut377's Avatar
Default questions on shiftkits and things
well i got my new tranny in about a month ago and it works good but i ve already had a little trouble with the thing bouncing on the rev limiter when im getting on it somtimes(always in 1st), but i was wondering if i put a trans go in would that solve that problem and if not what would?
Old Aug 10, 2008 | 05:30 AM
FLT's Avatar
FLT
A shift kit might help to make the trans shift firmer and maybe a bit quicker. However this sounds more like a tune issue or a band clearance issue. Are you running a higher stall converter? If so get a tune.
