LS1 4l60e into 94 LT1 Formula
Old Aug 17, 2008 | 05:26 PM
ws6manny's Avatar
Default LS1 4l60e into 94 LT1 Formula
Ive been searching for hours now. I cant find A clear answer. My tranny is going out and Im looking for a temporary replacement. A buddy of mine has an ls1 4l60e for sale and Im curious as to if it will work with my lt1. From what ive reasearched ive come up with the bell housings are different but thats about it. Is there anybody who can give me some clear advice on this topic?
Old Aug 17, 2008 | 05:39 PM
V8pwrdz28's Avatar
it will not work, period.
Old Aug 17, 2008 | 05:57 PM
Almostryan3's Avatar
That is a very informative answer, I thank you for your thorough and detailed response on why it will not work
Anyone with some actually explanation care to chime in?
Old Aug 17, 2008 | 06:25 PM
daniel6718's Avatar
it wont ive asked before also...has to do with the leingth of the converter, the lt1 tranyn will work in a ls1 since its deeper...but not a ls1 in a lt1 because the converter cant be made that short
i think its only 5/16 an inch off???
i always thought they could take that off the mounting tabs on the converter...
Old Aug 17, 2008 | 06:33 PM
So the LS1 4l60e has a deeper belhousing? So in the case that he mentioned changing the belhousing he can do it?
Old Aug 17, 2008 | 09:30 PM
ws6manny's Avatar
If thats so, wouldn't I just be able to switch the converter out to an lt1 converter? And what if I wanted to go with an aftermarket converter? Is it possible then?
Old Aug 17, 2008 | 10:14 PM
IronOutlaw's Avatar
It wont work. I just asked a similar question on here. Im gonna get a tranny out of a 93 1500 pickup or a 93-94 s10.
Old Aug 17, 2008 | 10:51 PM
daniel6718's Avatar
no cant swap bellhousings...he lt1 is non removeable
and no the lt1 converter wont work in a ls1...differant...
lets just leave it at it cant be done...if it could somebody would just make a custome converter for the swap...and have no changed to the tranny itself...but no1 has and it cant be done....
Old Aug 17, 2008 | 11:14 PM
so really only thing needed to be different is an LS1 converter thats 5/16" shorter? I'm sure if your ordered a converter from yank or something they could do that.
Old Aug 18, 2008 | 12:36 AM
Johnny@Xtreme_Trans's Avatar
Not only is the LS1 trans bellhousing Deeper to accommodate for the bigger torque converter, but the internal electronic components and valve body are different. The 3-2 downshift sol. is pwm in 1994 and on 96-up trannys have an on-off 3-2 sol. and the valve body also changed to accommodate for this change. Also in 1995-up the 4L60E trans has added a tcc pwm solenoid which the 1994 trans did not have. It is possible to install an LS1 trans in a LT1 car but you must change the bellhousing, pump stator, input drum, valve body from a 94 trans with all electronics, seperator plate, and wiring harness.
Old Aug 18, 2008 | 01:05 AM
performabuilt's Avatar
LS1Tech Sponsor
Actually from a mechanical stand point it can be done we did when we were using the astro dyno before we got a dyno. Converter was custom built then modified.
Electronically again Yes it can be done requires elimination of the 3-2 regulator valve like is done in the transgo kit and elimination of the function of the converter clutch regulator valve like we do to all our units, Then its just a matter of swapping the 3-2 solenoid as its a different ohm load, The PWM is not and issue though it must remain in place to block a hole in the valve body.
But really you would be better off just getting the right style 4l60e for you application
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 18, 2008 | 11:25 AM
Alright thank you for the clarification everyone.
Old Aug 18, 2008 | 11:31 AM
BlackTA96's Avatar
i had a friend that but an ls1 style 4l60 into his lt1 camaro...he didn't have any problems what so ever...
Old Aug 19, 2008 | 01:15 AM
ws6manny's Avatar
What about a 4l60e from any 94-97? Will that work. Or does it have to be 94 exactly?
Old Aug 19, 2008 | 01:54 AM
OOOOOO sick burn! Yeah I think these guys are on crack jk but seriously I have had two sitting right next to each other and they were freaking identical!
Old Aug 19, 2008 | 07:10 AM
FLT's Avatar
FLT
Keep in mind that the electronics in a 96 and 97 LT1's are the same as 98 and later LS1 vehicles. So if it were to fall into those years yes it would with a little work.
Tell you what, you be the Ginny pig and prove us trans guys wrong. Please do not come back crying if it does not work or you pop a computer. You have been told not to do so but then again "you can lead a horse to water but can you make him drink it?" Vince
Old Aug 19, 2008 | 07:59 AM
BlackTA96's Avatar
yea his camaro is a 97...guess that explains it then.
Old Aug 20, 2008 | 07:39 AM
BlackTA96's Avatar
will an ls1 4l60 bolt up to a lt1??
Old Oct 28, 2008 | 11:18 PM
camarolvr69's Avatar
What would you have to do to get an LT1 style 4l60e (from 1997 z28) to work with an LS1 motor??
Would it work if I used these parts?
http://www.crateenginedepot.com/stor...-P1342C19.aspx
http://www.crateenginedepot.com/stor...2-P1343C0.aspx
http://www.crateenginedepot.com/stor...3-P1344C0.aspx
Im planning my LS1 swap, and if its too much hassle to make it work I can always go with the newer style 4l60e, but I would like to be able to keep my trans.
Old Oct 29, 2008 | 07:54 AM
BlackTA96's Avatar
Just to clarify a one thing. A few of you guys have said that you need to change the bellhousing on the LS1 4L60E's for them to fit on a LT1. This is completly wrong. You just don't use the very top bolt hole. And honestly my friend didn't go through all the trouble you guys make it out to be. He used an LS1 converter and I believe he had to modify the holes in his flex plate a little. But thats all he did. The Transmission he has had was not built to go into a LT1. It was a built 4L60E though. Not sure who it was built by, but it came from San Antonio.
But as stated earlier, his car was a 97.
