LS1 4l60e into 94 LT1 Formula
bringing this thread back to life. I lost 3-4, probably 3-4 clutch packs, can get a 4l60e from a 99z28 for a very good price. It would be in a 97 ws6 Formula. Know what he did to the flexplate and converter???
the stock converters are diff bolt patterns...wiring is an easy fix pull the pan and swap them as far as i understand...the problem comes into the converter and depth situation..need a custom converter or a spacer between the motor and tranny like with a glide ect..then drill holes in the flywheel and a tci spacer for the crank snout...
i did the swap from a 94 tranny behind a ls1 keeping electronics working...no problem
