TC Lock/Unlock Ideas?
Old Oct 14, 2008 | 10:03 AM
usmc320's Avatar
great. thanks for the info.
Old Oct 17, 2008 | 01:03 PM
Mister Peebody's Avatar
What causes the PCM to send the unlock command to the converter? Is there a list available somewhere of all the things that trigger the PCM to send the unlock command?
Thank you for your input.
Old Oct 19, 2008 | 11:26 AM
rdrage728's Avatar
I hooked mine to a switch so i can control it myself. if it comes on under wot it could damage it so when im racing i leave it unlocked and when i get on the interstate i turn it on at about 60mph. its been like that for a while now and no problems.
Old Oct 23, 2008 | 06:16 PM
Aynbody?
Old Oct 23, 2008 | 06:50 PM
performabuilt's Avatar
LS1Tech Sponsor
1-tilt in and out throttle
2-random engine misfire
3-hitting the brake
4-excessive converter slip will set code p01970 and disable lockup
5-engine low temperature
6-heavy load detection maf related
There may be more these are some I am aware off
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 23, 2008 | 07:00 PM
johnLs1camaro's Avatar
yeah i had the same issue with unlocking on the highway, and it really sucked... mine ended up being in the tune, and I took it to a different tuner and got it right!!
Old Oct 23, 2008 | 07:04 PM
Red 01SS's Avatar
Good luck, my Yank does the same thing and everyone told me it was normal, even some of the people who have posted in this thread
Old Oct 23, 2008 | 09:20 PM
382ssz28's Avatar
Mine was a tuning issue. I had the HP Tuner 1.7 and everything was fine. I upgraded to the MPVI PRO 2.2 and it had more functions. They told me that they had downloaded my tune. GREAT!. Not so great. When I took the car to get it tuned, they had found the problem and corrected it. I have the Vetronix scanner at our shop. I could manually lock the converter, (Brand new Vigilante 4000), for ever. I felt the converter would be OK, but better safe than sorry. I thought it was something I missed when I did the trans. It was driving me nuts! I was in the process of sending the converter to get checked when I had taken the car to the tuner because I had to know. I'm no tuner either. They found it right away, Vector Motorsports. I would go to a tuner ASAP as not to burn up the converter clutch. They had to get rid of the missfire codes, #2 on Performa's list. If you have engine lights on the dash, this would be a telltale sign, I was told. Good Luck.
PS, I think #4 is P1870, lol.
Old Oct 26, 2008 | 03:56 PM
Thanks for the replies! I get no trouble codes or check engine light, that is what puzzles me most. I will get it to a tuner. Thanks again.
