Is this trans fried, or reparirable?
Old Aug 24, 2008 | 09:04 PM
IronOutlaw's Avatar
Default Is this trans fried, or reparirable?
I just bought a 97 camaro for REAL cheap, and the guy said it needed a new tranny. I know almost nothing about transmissions and am not sure what can be repaired on one.
But anyways, its got an slp 2600 stall, but im not sure if he put a cooler in with it which i know is a must. He said he didnt drive it much with the stall and it went out one day, so he parked it. When i got it, it was very low in transmission fluid so i filled it up, none leaked out. It has a perfect reverse, park and neutral. I only pulls foward on a flat surface but just barely, and when its in drive it make a loud whining sound.
Is there any way that is something that can be repaired or am i going to need a full rebuild?
Old Aug 24, 2008 | 09:08 PM
performabuilt's Avatar
LS1Tech Sponsor
Based on your description you are going to have to fully rebuild or replace the transmission. Making noise you likely have hard parts damage so replacing is probably the best idea. Please feel free to look at what we have to offer and also look at any of the sponsors here. I feel we all build good products.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 24, 2008 | 09:19 PM
IronOutlaw's Avatar
Thanks for the quick response performabuilt. Ill check out your website but it may be a while until i can afford a rebuild...
Old Aug 24, 2008 | 09:30 PM
IronOutlaw's Avatar
I was checking craigslist and found a 4l60e out of a 2000 4.3 s10. Will this work with an lt1 or is it like an lsx style 4l60e?
Old Aug 24, 2008 | 09:34 PM
LS1Tech Sponsor
It can be made to work as it is and LT-1 style but your better off getting what you need for your car rather than rigging it up
__________________
Call 888-744-6542
Old Aug 24, 2008 | 10:13 PM
IronOutlaw's Avatar
I just need to get it on the road so i can sell my old car and pay my loan off while making some extra $$$. What will need to be done to make it work? will it need a special torque converter or will i just need to change the tail shaft?
I know i need to go with a rebuilt unit but thats not happening till next summer. Im about to start school, so im not going to get to work any extra hours for a while, but next summer im definitly going with a rebuilt unit and a big stall.
