Slipping?
Old Aug 25, 2008 | 09:50 PM
schmidtycamaro's Avatar
Question Slipping?
Hey guys,
I have a 2001 Camaro Z28. A4 so 4l60e transmission. I feel like the transmission may be slipping. Either that or its hesitating. I notice it most when I go around turns. What I mean by this is I will let off the throttle completely going around a corner then when I press back down on the throttle it is like it slips or hesitates to go into gear. Any ideas or suggestions are welcome. If not, I do have a local shop I really trust to check it out for me but..that's also big time diagnostic fee haha
Thanks in advance
Old Aug 25, 2008 | 10:40 PM
Johnny@Xtreme_Trans's Avatar
Check fluid level and condition.
Old Aug 26, 2008 | 01:46 AM
performabuilt's Avatar
LS1Tech Sponsor
Agreed check fluid level first make sure its at top of cross hatch warm
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 26, 2008 | 08:45 AM
Thanks! That seems to have done the trick. For now anyway. I was thinking of getting the transmission flushed and new fluid put back in soon anyway. Since I just bought it about a week ago, I wanna be sure about whats in there since I don't know what the original owner/dealership has in there or did to it haha
Thanks again!
Old Aug 26, 2008 | 12:16 PM
You should look for the leak first and then change the filter and fluid, that way when you pull the pan you can look for excessive metal or debris. If you flush the trans, the pan is not removed and the filter is not changed.
