Need Shift solenoid help!!!!
Well its over a year now and im still having issues with 2-3 solenoid.As you can see from my post all that I have done.Last time we talked you gave me instructions on what wires I need to run to bypass any short in the 2-3 solenoid wiring and I did that.The car does not do it as much as it used to but still does it anywhere from 2-3 times a week or sometimes not for a month.I do notice it does it when im hovering around the 35 to 50 mph where it wants to shift.It either shifts fine or it will start to act up(bucking)and then go into limp mode.If im on the highway no problem but around 35-50 it can go either way.I know gm had some kind of shifting issue around the parameters and that it could be deleted but by buying a new transmission.When it does act up if I shut it off while coasting it will go away .When it does go away it either goes away untill next time it deciedes to or it will do it again or it will go away for a few minutes and do it again.Frank I work at a shop on the weekends and have tried all the possible glitches and still can not stop it.I even make sure the tire pressure is on spot so it will not throw off the speed sensor .Again I ask for some guidance.
Thank you
Kevin
