trans exploded
Old Sep 2, 2008 | 04:15 PM
camaro-94-z28's Avatar
Question trans exploded
long story short light turned yellow hit the throttle 4l60e exploded.
ok now were planning on ordering a performa built transmission with a converter 2marrow morning. just a few questions do they offer a discount to tech members? ive been looking on other sites( decided on performa though) is the a diffrence between one and 2 pieces? and how was everyones experince with performa? if my trans is non rebuildable in any way (shot pieces through the case) can i still send it in for a discount?
Old Sep 2, 2008 | 04:22 PM
performabuilt's Avatar
LS1Tech Sponsor
we do not offer a discount to forum members per say but you do get the sale price this week on whichever unit you want.
You can send in your old unit I cannot say you will get the full credit on the buy back but you should get something.
You don't need to worry about 1 or 2 piece case we will make sure you get what you need for your application
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 2, 2008 | 04:34 PM
ok thanks. i herdthat if you dont start using synthetic in a trans theres no point in switching later. so do urs come with synthetic? can i request that it does? (do they come with any fluid at all?)
Old Sep 2, 2008 | 06:46 PM
LS1Tech Sponsor
Only residual fluid from the dyno run and you can use any fluid you like as long as it meets or exceeds dexron 3 requirements
__________________
Call 888-744-6542
Old Sep 3, 2008 | 07:43 AM
ok thanks. i orderd level 1 about 5 mins ago. im the one who put the vin # in for the gears. im 90% sure there 3.23's but ill go to the shop and get the code off the door if you need that
Old Sep 3, 2008 | 09:36 AM
LS1Tech Sponsor
Thanks and the information your provided is all I need,
__________________
Call 888-744-6542
Old Sep 8, 2008 | 01:53 PM
ok so the trans got deliverd tto the shop. thanks for the ultra fast shipping.
now is there a break in period with the trans or anything special i should do?
and we can i make my first wot pull its been killing me i havent gone wot in a few months trying to perseve that old trans
Old Sep 8, 2008 | 02:49 PM
ws6t3rror's Avatar
I dont know about performabuilt. Usually though I dump 5-6 quarts in and then start the car and top it off make sure its warmed up some check for leaks. Then put the car up on jack stands, and put the car into reverse and let it idle in reverse for a minute or so applying the brakes to make it stop a time or two. Then put the brakes on and put it into d and run it from 1-4 about five times or so very very easily. Then I take it around the block babying it and make sure i'm satisfied with the fluid level when I get back.
After that its pretty much in gods hands and its only going to get worse from that moment on. I start driving it as hard as I want after that.
Edit: It will take a lot of fluid to get her full 10-15quarts depending on your cooler and lines and torque converter. There is no such thing as a little low with a 4l60e, i run mine about 1/2-1 quart overfull when hot.
Old Sep 8, 2008 | 03:00 PM
LS1Tech Sponsor
The only break in needed is after you do the initial run in and make sure full of fluid let car set overnight then start allow to warm then make sure fluid is still at top of cross hatch
Frank
As he mentioned above there no such thing as a little low
__________________
Call 888-744-6542
Old Sep 8, 2008 | 04:16 PM
ws6t3rror's Avatar
Oh thats right you guys run yours through the gears on the dyno nevermind about running it through the gears on jack stands .
Old Sep 9, 2008 | 05:42 PM
is an 1800 to 2000 conveter stock size cause my shifts points seem off and it seems like its taking a whole lot more power to move the car
Old Sep 9, 2008 | 06:01 PM
LS1Tech Sponsor
stock is around 1400 so it may feel a little different with and 1800-2000
__________________
Call 888-744-6542
Old Sep 9, 2008 | 08:24 PM
so is that enough for me to get a tune?
Old Sep 9, 2008 | 08:53 PM
LS1Tech Sponsor
No though a tune can always be helpful it can really wake up a performance automatic by putting shift points , kick down etc in more power oriented places under throttle
__________________
Call 888-744-6542
