help high idle and long shift timing
Old Sep 5, 2008 | 10:51 AM
mattz28zx6r's Avatar
Default help high idle and long shift timing
2001 Camaro Ls1
Have high idle at times and when the high idle occurs my transmission has long shifts. My transmission is from performabuilt and is level 2 transmission. No codes found. If anyone has any ideas what could be the cause please let me know. Also my car is cammed if that makes a difference.
thanks for your help
Matt
Old Sep 5, 2008 | 01:44 PM
performabuilt's Avatar
LS1Tech Sponsor
I would look at data from TPS and MAF both can affect idle and trans performance and or even cause trans damage. Not having a code does not necessarily mean you don't have a bad sensor
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 5, 2008 | 02:12 PM
BadA$$'s Avatar
Any Vacum leaks?? I know some leaks can cause long and hard shifts.
Old Sep 10, 2008 | 10:00 AM
It was my TPS thanks
Old Sep 10, 2008 | 11:15 AM
LS1Tech Sponsor
Good you found the problem
__________________
Call 888-744-6542
