hard shifting 4L60
Old Sep 20, 2008 | 01:48 PM
87aero's Avatar
Default hard shifting 4L60
My 98 Z has a really hard shift, especially on the 1-2 shift. The car seems like it is at full line pressure. When you pull it into gear from park, it drops hard into gear and if cruising at highway speeds and you tap the brake, the lockup disengages firmly where you can obviously feel it. Any input on what could be causing it. I was told the valve body is stuck, is this true or is it something else more simple.
Thanks
Old Sep 20, 2008 | 02:07 PM
performabuilt's Avatar
LS1Tech Sponsor
Well first do you have any ses lights codes?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 20, 2008 | 04:14 PM
MadIceV8's Avatar
Customizing Director
Also make sure to check your fluid level.
Old Sep 20, 2008 | 10:13 PM
87aero's Avatar
fluid level is good and there are no codes. it had an o2 code and that was it.
Old Sep 20, 2008 | 10:32 PM
LS1Tech Sponsor
My guess would e a mechanically bad PCS that would not set a code and would cause the issue you describe
__________________
Call 888-744-6542
Old Sep 21, 2008 | 08:56 AM
87aero's Avatar
PCS, not sure what that is. I am not real fmiliar with these trannies.
Old Sep 21, 2008 | 10:15 AM
LS1Tech Sponsor
Pressure control solenoid.
__________________
Call 888-744-6542
Old Sep 21, 2008 | 02:12 PM
MYSTIC-1SC's Avatar
is it normal to feel the converter unlocking, I assume thats what i feel when you hit the brakes a highway speed, not much but you can feel something happening nothing bad, but after reading this i hope just because you can feel the converter unlocking i hope its not a bad thing, my mods are in sig.
Old Sep 21, 2008 | 06:35 PM
MYSTIC-1SC's Avatar
??????????? anyone?
Old Sep 21, 2008 | 06:53 PM
87aero's Avatar
mine is not a normal converter unlock. it is more like a downshift. I'd say u r good.
Old Sep 21, 2008 | 09:12 PM
MYSTIC-1SC's Avatar
thanks
Old Sep 24, 2008 | 08:36 AM
87aero's Avatar
That did the trick. thanks for the info. A local guy was trying to get me to change the whole valve body. Thanks for saving me that extra 300 dollars.
