Experts on Stall, Chime in. Yank.
Old Sep 28, 2008 | 05:52 PM
tording99Z28's Avatar
I went with the SS3600 and I wish I had gone 4000. When its time for a rebuild I will have it re-stalled to a 4000.
Old Sep 28, 2008 | 09:49 PM
dnkynrbk's Avatar
for a dd driver I would do a 3500 stall from yank or another sponser on here and stay with the 3:42 gears that what I ran and was perfect for cursing or drag racing. Plus you can stay with the 26 inch tall tire if you go to the 3:73s then you will have to run a 28inch tall tire plus with 373 your gas milage will not be as good. If you go with too big of a stall your car will be engaging and disgaging while driving around town. Which will wear on the stall for a dd a 4000 is to high. And once again it depends on your goals.
I ran 3:42 gears a tci 3500 stall and was awesome at crusing and ran a 10.36 on a stock 10 bolt at the track.
Old Sep 29, 2008 | 07:50 PM
LS1_K1DD's Avatar
^Its either a 3800 2.16str by FTI, or a 3400 2.45str by Edge. Can't decide!
