4l80e differnces?
Old Oct 2, 2008 | 06:58 PM
rubbersdown's Avatar
Default 4l80e differnces?
is there a difference in the 4wd and 2wd 4l80e? or are the same and the 4wd just has a transfer case?
Old Oct 2, 2008 | 07:20 PM
MUSTANGBRKR02's Avatar
i believe you need a different output shaft and a tailshaft to swap it in.
Old Oct 2, 2008 | 07:36 PM
Blk_Ws6's Avatar
It holds more power right the 4l80 i mean and how much does it weight over the 60e?
Old Oct 3, 2008 | 04:17 AM
TurboAv's Avatar
In the FAQ pages it lists weights, but if memory serves a 4l60 is around 200lbs and a 4l80 is about 275lbs.
Old Oct 3, 2008 | 05:07 PM
mine is about 210 dry
Old Oct 3, 2008 | 05:22 PM
jakeshoe's Avatar
A 2WD 4L80E is 178 lbs dry without converter.
Most people aren't going to install a 4L80E with the stock converter and an aftermarket piece is considerably lighter, so the trans should be weighed without it for an accurate comparison.
4L60E is ~140 ish. I can weigh an LT1 unit, but don't have any LS1 units in the shop right now.
Old Oct 3, 2008 | 07:50 PM
that 210 was with the converter
