TCI 3000,3500 guys in here please.
I would like to hear from others. What 60's are you pulling(N/A)?
LOL 1999 R/A T/A,LS6 intake,SLP 85mm mass air,MAFT,Thundervolt 10.4mm wire,TR5s,ASP pulley,Grant. lid,K&N,Hooker LTs,OF y-pipe,SLP daul dual catback,TCI SSF3500,Trans Go shift kit,GM 3.73,BMR subframes,BMR rear LCs,BMR realoaction brackets,Weld Super Lites 15x3 15x10,ET Streets 26x11.5,V-6 springs in rear,No front sway bar,no spare tire
Computer tuning to delete TQ management,EGR,Air,rear O2s,set cooling fans,3.73s,no air-fuel or timing tuning
Tony
2 more questions for you. What was the weather like or (DA)? Could you give me a run down of your time slip to compare with? Trending Topics
Tony
I'm not trying to cause any disbelief. Just trying to figure mine out. BTW my trap speeds corrected are 111(320-330hp range) and your pulling 113mph(350+hp). Do 02's have that much more hp? Where does it come from?IMKMFAST: Thanks for your help. Your et's & mph on your runs would help me out a lot I'm trying to make it to the 11's SI.
If you'll give me a complete listing of your mods and raceweight, I'll try to help you hunt down your missing MPH compared to mine (it dynoed 359 with the converter locked and through the cuttout, btw.) 111 MPH is still very good for a bolt-on car! The difference in our MPHs may well have been density altitude. I don't know what mine was that day but it was pretty good.
2000 Camaro SS A4
MODS:
Engine: No internal, ASP Pulley, NGK TR-6's
Computer: Diablo Predator
Induction: K&N, Direct-Flo Lid, smooth bellows, FTRA
Exhaust: 1 3/4" Jet-Hot LT's, 3" ORY-pipe, 3" Cut-out, 3" Borla cat-bak
Trans: TCI SSF 3500, B&M trans cooler
Suspension: ES poly trans mout, BMR LCA's w/ relocation brackets,
DMS lowering springs,
Wheels & Tires: 35th Aniv. SS wheels, 17x9 w/275/40/17 Nitto 555's(front),
17x11(widened) w/315/30/17 Nitto DR's(rear)
Weight: 3500(car only)
I'm only trapping 108.7mph w/DA of 1779'.
Corrected to 0' DA it should run 111mph.Do you think there is anything to gain going to 3.73 gears? Any ideas you have would be greatly appreciated.
Steele Dragway.....Mar. 1 2003
1.69...7.80...89.32...12.29...109.70
1.64...7.78...89.52...12.28...109.42
1.63...7.78...89.14...12.28...109.62
1.60...7.71...89.83...12.19...110.26
Lassiter Mtn. Dragway...Mar. 16 2003 1/8 Track
1.64...7.72...88.26
1.59...7.74...87.55
Nothing spectacular,but maybe it will give you something for comparison.
My guest for 11s will be should happen next weekend.Monday I'm going to install stageII PPS heads,comp XER 224,and a NX wet kit.Hopefully my Wolfe Craft roll bar will be here in a couple of weeks.Got to get ready for Thunder in nov.
Nice setup yourself btw.
Who widened your rear wheels?
Well good luck,and I hope some of this helps.
Tony
I really do'nt think there is much difference in the 3.23/3.73 thing though.I raced I friend of mine one night at the track and we had the same mods at the time,only diff. was the gears.She had a 02 T/A 'vert w/3.73 & mine had 3.23s.The diff. in our runs was 0.01.The main reason I put 3.73s in mine was because alot of my driving around town is on roads that have speed limits of about 40-50mph.The 3.73 have a nice down shift kick about 50-55,with the 3.23s is was more like 65.On the interstate with either gear you can usually get the kick you want if somebody pulls up on you.With the 3.73s the kick is much better a lower speeds.If half a fender is all you need to call it a win,you'll get it quicker w/3.73s
