Transmission Trouble...Need a little help
Now after all that I'm having trouble with the tranny. The torque converter and flywheel turn with the motor very smoothly but the tranny wont spin once i put it in gear and im not sure what the problem is.
There is enough fluid in the tranny and converter (11 quarts) but i dont know whats going on.
I did notice that when i mated the tranny and engine the torque converter pads were around 1/2 inch to an inch away from the flexplate and when i tightened the converter to the flexplate it pulled it off the input shaft about that much.
So im not sure what i need to do. Also there is tranny fluid slowly leaking from the bellhousing/torque converter area. I'm not sure why if i used all "OEM" parts that it would have pulled the converter off the shaft.
SOrry for the long post but it would be greatly appreciated if someone would help!!!!
http://cgi.ebay.com/ebaymotors/ws/eB...m=250270698049
but it actually doesn;t look like the one in the picture it looks like this one below:
Let me know and if that would cause it to not spin the shaft or something
Thanks!
The stator can be pressed out of the pump but you would be better to have the correct pump but I can say this most be corrected
How much would one run me if I bought it from you?
I want to go cheap because I am going swap a TH400 in it soon but would like it to run in the mean time as I'm researching and buying the necessary parts for the swap
I need the cheapest solution (under $50 preferably)
http://cgi.ebay.com/ebaymotors/4L60E...spagenameZWD1V
And if i just bought the stator it will work right or is the pump not going to flow fluid or something weird?
here is a pic of the one i bought....the guy said it would work for v8s 93 and up and it was $10 new
Yes that is the right stator.
