Job Opportunities at Livernois Motorsports
Below is a list of our current job opportunities. To enquire about a job, please send your resume to info@livernoismotorsports.com. Pay is fully based on experience. Thank you for your interest.
Engine Builder
We are looking for an experienced, highly skilled engine builder. This person needs to have at least 5 years experience in racing engine technologies, as well as current techniques and advanced methods of engine building. Must work well with others and cooperate with team to meet goals. Our core business is Ford 4.6/5.4 modular and GM LS-Series Engines.
Minimum Position Specifications
Physical Requirements
Cylinder Head Tech
We are looking for a self motivated, experienced cylinder head technician. This person must be able to work with others in his area as well as the shop. This person should ideally have 5+ years experience in this field. A background in racing cylinder head technology and knowledge of the parts and current product offerings is essential. Must be easy to work with and open to learning new techniques.
Duties
Install Seats, Perform Valvejobs, Blend Seats, Airflow Development, SF600 flowbench work, mill heads, install guides, hone guides, ream guides, valve finishing, cylinder head assembly
Engine Machinist
We are looking for an experienced individual who has 5+ years of machining experience. This person must be self motivated with a strong desire to do only the highest quality of work. It is also necessary to have an understanding of current engine and machining theories and techniques as well as be able to operate both new and older machines.
Duties
General engine machining and engine machine related work. Operate different types of machines to produce finish machined blocks, heads, crankshafts, etc. for use in engine department.
Engine Builder
- 5+ Years Experience
- Have own Tools
- Operate bore gauges, micrometers, take precision readings
- Lift up to 50 lbs
- Capable of working an 8-10 hour day
Cylinder Head Tech
- Have own Tools
- Serdi Machine Operation (NEWEN Machine operation a plus)
- Lift up to 50 lbs
Duties
Engine Machinist
- Have own Tools
- Machine Knowledge– Align Hone, Cylinder Hone, Rod Hone, Decking, Milling, Bridgeport, Lathe, Cylinder Bore
- Lift up to 50 lbs
- 2Capable of working an 8-10 hour day
Duties
