Welding career anyone?
You'll hear mixed stories no matter what the feild, welding, Doctor ,**** Star anything its up to the person involved to make a better future for themself.. Theres Nodoubt Welding is a tough dirty demanding job and some people cant hack the work load, hours or simply having to wake up every morning.Im sure they pay in certian areas is equal to or greater than someone sitting in an office with a college degree you prob wont get it if your welding production or small job shop type stuff, its nobodys fault a person only makes 25 an hour... but them selves.Im looking into doing Any type of Nuclear/pressure vessel or aerospace welding
youre broke because u want to
its true
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
i'm still going to apply there, my neighbor that i talked to has been doing that for about 30 years now, not with that only company but has been a welder for that long. the thing i liked about that company was that it was large within itself to where you could do different fields when ever you felt like needing a change of pace. come monday i'm going to apply and hopefully get interviewed so i can leave this current job i'm at. dosnt look like they want to move me up anywhere and keep me at that same spot
my cousin works for the gas company. he makes damn good money but its back breaking work.
and dangerous.
he nearly got killed a few years back when a spark from a backhoe ignited the gas that was leaking from a line he was working on.
and dangerous.
I wouldnt underwater weld if it was the last job on earth. The avg. lifespan of an underwater welder is not very long. I heard of a class that was in a pool, one guy screwed something up while underwater and fried his entire class in the swimmng pool. Killed everyone instantly.
I like welding fine as a hobby but I wouldn't want
to do it for a living. As trades go it's got a lot of
hazards and as far as conditions, down here in
Florida you see the welding being done in open
steel-roof sheds, you're all bundled up with no
cooling but a floor fan and it's 90+ degrees outside
and more like 100+ inside. Screw that. I can only
take 10-15 minutes in my shed and I need a
cool-off break. Ain't going to get that luxury when
you're on the time clock. No union down here
either. Just rednecks making sparks and getting
beat up old, early.
beat up old, early.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm a maintenance welder/millwright, and as much as I love welding I doubt you'd ever catch me pipelining. But I probably won't have to. If you want a nice clean job pick up a tig torch and learn how to well stainless, aluminum, titanium, ect. You can make a lot of money welding non-ferrous metals if you can do a good job of it. And down the road you can become a CWI(certified welding inspector) or a welding engineer, and your welding experience will be a huge help.
Check out www.aws.org They have a ton of info on schools, employers, ect.
There are a bunch of really good welding forums. But as a general rule welders think they know it all, and their way is the only way to do things...so take it all with a grain of salt.
www.millerwelds.com has a good forum, and so does hobart.
-Josh
Well I just started Welding School 3 days ago. We've been cutting plates with Acet/Oxy torches, and im "ok" at it, but I like it a lot. Im better with stick and that comes later in the course, and I want to get into Underwater Welding eventually. As for working conditions, I used to work at an Acid Refinery plant and guys welded all day long and went home just fine unless someone wasnt paying attention.
You take risks at whateve job you have. What if an accountant decides to flip out and bring a gun to work, or a mailman gets in a hit and run, etc? I'd rather travel to globe, diving/welding making a great amount of money, and take the safety precautions, than sit in a desk and feel like im rotting away.. crunching paperwork. Bu thats just me
And with the underwater welding, there aren't any precautions you can take to make it as safe as "above water" welding. It's not the risk of sudden death or injury , it's the physical toll it takes on you. Talking to other guys that have traveled the globe welding, they told me underwater welders are done within 10 years because of what their body goes through.
But if you dig the water, and you can weld, and you want to travel, that may be a cool thing to do for a few years
-Josh
To the OP, have you ever welded before? I had welding class ALL day for my senior year in high school. It was awesome. First half of the day I welded and then was a student teacher, the second half of the day, I got to go work at a local power plant as school to work.
I entered welding competitions, and even got a welding scholarship to go to college, but turned it down to go straight to work. I started out of school in 97 welding on trains making about $18 I think it was. I got tired of that and went to a place making antenna towers, welding in a production shop. I went from there to a union ironworking job where all the old journeymen were pissed off cause I could lay down a bead better than they thought I should be able to.
Then one day a screwed up my back lifting up a bundle of rebar.![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I did a short stint in a sheetmetal fab shop making plastic tank molds, but there was more metal work in there than welding.
Now I own and drive a truck.
HAHAHAHAHAHAHAHAHAHAHA. Welding is fun man, and if you like doing it, do it. Not every job is in an air-conditioned shop 9-5. Someone in the country has to be outside welding in the heat.....that's how things get done. Don't listen to someone tell you that it is the worst.......heck don't decide on what I said. Go try it out for yourself. That's the only way you are going to know if YOU like it or not.
There is ALWAYS going to be a job opening for a welder somewhere.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
i did a little welding for work and HATED IT!!! Hot as fack in the summer and still pretty damn hot in the winter as well. tig is not bad at all, nowhere near as hot and ALOT cleaner. do yourself a favor and learn to tig. then get a job at a factory that does alot of it. if your really good then starting pay "could" be upwards of 20 an hour.
#34
Village Idiot
You gotta stand all day welding and my back hurts and I have double vision just thinking about that. I'm healthy and fit too...How do you guys do it? Torch and sheild, heat and standing all day... Diving and welding sounds cool as I am cerified, just don't want to get the bens or shocked...
Have fun it's all you guys... I'm getting into Nursing as gay as that sounds.. Lot's of old people these days and not enough nurses to care for them.....100k a year to chill and change old man diapers..... 10-20 minutes of pure agony changing bed pans and what not, but the rest is all good.. If your lucky you might get in on the old mans will too...
Tunneling is a great paying job too, saw a special on discovery channel in New York, those tunnel workers make real bank working city underground jobs..
#37
I know lots of welders and they are nuts, literally crazy people but are awesome welders. If you want to make money at it, I'd pick a state that produces oil and go from there. I know for a fact AK needs welders and oil services companies start out at around $25-$30/hr for people with their plate and pipe certs. Usually they end up around $50/hr after a few years
#38
The most dangerous thing about underwater welding is the fact that your diving to do it. the pressure of the water as your down there is what takes a toll on you, but most of the time your in shallow depths. but the pay is killer. and the welding is a reverse polarity, so thats not the danger, its the diving.
#39
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
#40
I work nuclear power plants for DZ Atlantic right now and I LOVE it. If you get into nuclear that is the place to go. It will ruin you though. I actually work about 6 hours out of a 10 hour shift. Nothing is done in a hurry, you get time to eat breakfast, an hour for lunch, and a bunch of what we call "nuclear hold" down time. That is all on the clock. A starting welder at Duke power for DZ Atlantic is 25 an hour, and after your first shutdown you get 27. Top pay is 31 an hour. You also get $525 a week for per diem, and that is tax free. In a 60 hour week i usually bring home around 1800 and that is claiming single and zero on my taxes. Welding is great if you can do it, and is one of the careers in highest demand right now.
