Ward's 10 Best Engines for 2009
#61
http://www.gilbertautoparts.com/Chev...ockV8s/LS1.cfm
http://www.corvetteactioncenter.com/...t4-weight.html
http://www.whiteracingproducts.com/i...oducts_id=1114
Are you seriously that dense? Cost of the engines... A brand new LS2 can be bought for a little over $5,000, while the LT5 when new went in the $20Ks.
And the C6 ZR1 is $106,000 new, nice try though.
Check on the as new price of the C4 ZR1 compared to the C4 Z51, and then compare that to the C5 Z06...
Then why does the LS6 make the same power (and more torque through out the whole rev range) than the LT5 with the same displacement? Your argument is flawed and moronic. A DOHC engine is only going to make more power/torque if it is tuned to do so, your making it sound like it magically gains power from the OHCs.
What about cost? The Z06 is 70k new and the ZR1 is 120k new.
I don't think cost is that much of an issue considering the cost of the cars.
Again, given the same displacement DOHC will make more power, torque throughout a longer rpm range.
#62
Its deeper than just 4 valves per cylinder. Its the ability to change cam timing on both the intake and exhaust cams. Therefor a higher degree of tuning can be implimented. You also have a more efficient combustion since the spark plug is placed in the middle of the combustion chamber.
#63
***Repost Police***
Originally Posted by JD_AMG;10810140
Then why does the LS6 make the same power (and more torque through out the whole rev range) than the LT5 with the same displacement? Your argument is flawed and moronic. A DOHC engine is only going to make more power/torque if it is [I
tuned [/I]to do so, your making it sound like it magically gains power from the OHCs.
The point was the ability to do variable valve timing, not just change the timing.
#64
In a racing application where a car would be making north of 1000hp+ I wouldn't mind a V-DOHC engine because the added weight would really be minuscule compared to the power/torque its making. But for the 99.9% rest of the world with street performance cars, a V-OHV engine is more efficient because of weight, size, and cost.
#65
The MSRP on the ZR1 is 103,xxx without any options. Show me one person that paid 103k
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
http://www.automotive.com/2009/101/c...ing/index.html
Its funny you want to bring up the price of a motor when the LS7 is 14k new lol
#66
The weight is 596lbs(page two fully dressed)
The MSRP on the ZR1 is 103,xxx without any options. Show me one person that paid 103k![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#67
Weight is 390lbs out of crate.
Show me one person that paid $70,000 for a GTR![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
For a 505hp/470ft.lbs, 440lbs engine with dry sump thats really not that bad of a deal.
#68
#69
#70
***Repost Police***
Exactly my point.
#71
Back to pushrod vs dohc:
Lets clarify this a little bit. First of all, the 1993 lt1 produced 300hp@5000rpm and 340lb-ft@3600rpm. It wasn't until 96 that the lt4 produced 330hp. The lt5 in the 93 zr1 produced 405hp@5900rpm and 400lb-ft@4000rpm. Now that we're comparing apples to apples, there is a 105hp and 60lb-ft difference in output, let alone a narrower powerband, all from the same displacement.
As a matter of fact, now the difference in output is a staggering 35% and in torque 17.6%. If that is not a significant figure, I don't know what is. Ironically, these two engines were put in the same chassis side by side and both corvettes, so i don't see how any vette fan could be biased towards one or the other either.
Fact of matter is, it wasn't until 10 years after the first ZR1 that chevrolet matched the output of the powerplant with the ls6.
Consider this and you would get an idea of what chevy could come up with if they were to consider another dohc v8 for the vette.
#72
Yes, because 405hp LS6 = $7,000ish and 405hp LT5 (new) = $20,000ish.
#73
#74
http://www.mulsannescorner.com/moparv8.html
http://www.mulsannescorner.com/mugenv8.html
Most racing dohc motors are just as light as pushrod motors. So the tech is there.
#75
![Lightbulb](https://ls1tech.com/forums/images/icons/icon3.gif)
GM/Chevrolet doesn't use that OHV design by accident or because they don't have enough engineering prowess (because they do)...they use it because they weighed all of their objectives and needs and intentionally chose to use an OHV design.
#76
I agree they are the industry standard but for different reasons (marketing). "Smoothnes", NVH, feel, all have much more to do with the car and how its built than the engine (motor mounts, firewall, exhaust, transmission, where the engine is mounted etc. etc.). I've driven plenty of OHV's and OHC engines of various displacements and cylinders and can tell you OHC's are not automatically smoother with less NVH. As I'm sure you know the LS6 in the Gen 1 CTS-V is identical to the LS6 in the C5 Z06, but magically the CTS-V's LS6 felt smoother and had less NVH. That same LS6 was also smoother, with less NVH (ignoring the louder exhaust note) than the base CTS's 3.2L DOHC V6. And that same V6 feels no smoother than GM's 3600 OHV V6 (although its more 'crisp' IMO).
#77
Yes, they'd then have a motor that 1) weighs more (more weight = less fuel economy), 2) is physically larger (meaning a less aerodynamic body to put it in = again less fuel efficiency and potentially slower top speeds) and 3) costs more to produce (potentially lower sales).
-If they use the same trans/gearing, the LT5 would be more fuel efficient
-why would the top speed be less, it would be more with the same exact setup and gearing.
We will see what the future holds for the vette. But I guarantee you in the near future, it will be dohc design. Just like the new V6 Caddies
#78
#79
The mugen to mopar example was made to clarify my point that dohc engines can and are made compact and lightweight, but that for now it is limited due to material usage and cost. 20 years ago, carbon fibres and space age alloys were seldom seen in anything non exotic, but these days they are much more common (specially the alloys) and this trend will continue.
#80
I agree they are the industry standard but for different reasons (marketing). "Smoothnes", NVH, feel, all have much more to do with the car and how its built than the engine (motor mounts, firewall, exhaust, transmission, where the engine is mounted etc. etc.). I've driven plenty of OHV's and OHC engines of various displacements and cylinders and can tell you OHC's are not automatically smoother with less NVH. .
Remeber OHC is old too. 1913ish and used in production in the 20's
GM had straight OHC 6s in the 60's.
That debate is crazy, the one that makes the most power with the least moving parts wins.
