CTS-V misfire? P0300/P0500 codes?
Well, this morning I started getting a misfire and then the car started dying on idle...when I limped it home and scaned it I get P0300 misfire code and also P0500 speed sensor codes? Pulled car into garage and now can't get it into R to back it out? What sensor do I need to get to fix this...I guess I was thinking that this was probably fule related but with no R maybe it is the speed sensor? This is just a simple swap or something? Napa can't find a part number for speed sensor except for the one with the wheel bearing/hub assembly?
Any help?
Any help?
Vehicle Speed Sensor is at the rear tail housing on the right side of the trans.,and
Tighten the vehicle speed sensor bolt to 10 N·m (89 lb in).,p0300 will set when the pcm have no signal form the vss and the pcm will shut off the fuel and u will get engine misfire
code,i dont have the parts # u need but u can go to any gm dealer and get the parts,
o dtc p0500 is not for the wheel speed sensor is for powertrans (engine and trans)
