275s are little... lets go nuts.
25.4mm in an inch, so each "size up" is about .39 inches in width.
The series, or aspect ratio (second number, 35,40,45,50, etc.) refers to the height of the sidewall expressed as a percentage of the tire's width. For example, then, a 275/45/18 would have a taller sidewall than a 275/40/18.
That's exactly what I was looking for! Thank you!
So If I went up from a stock 245 to a 275 in the rear, i would be just over an inch wider (or .39's of an inch x 3 = 1.17 inches wider)?
Slightly off topic... some 275's may seem wider than others... usually due to having a wider tread with. Type and design of the tire influences this... where a normal passenger car tire may have the section section width of XXX, its tread width may be narrower, for a more tapered in appearance from the back. Typically performance tires are more square shouldered, with the tread with being much closer to the XXX section width. Make sense?
Basically, yes. Remember - You will need to choose the correct aspect ratio to keep the overall tire diameter correct, for the sake of the Stability Control system. Example - With the stock 245/45/18 on the front, if you put a 275/35/18 on the back it will be too small of an overall diameter in the back and it'll play hell with the Stability/Traction control... since the rear tires will be completing more revolutions per distance relative to the fronts, it will be interpreted as wheelspin.
I would love to see some pics if you don't mind.
#34
They stick out a VERY little bit!!! and my car is lowered a good amount on coilovers and doesnt rub the tire at all. Now i wouldnt recommend having yoru stockers widened to 10" because of clearance issues with a trailing arm, and the fact that i have to run longer studs and a spacer in the rear. If you go with 9.5" you can fit the same tire and you wont have to clearance much if anything.
as far as widening the wheels talk to your local Discount tire co. my roomate works there and did it for me
#36
#38
I was quoted $250-300 per wheel to have two of my buddy's Vette wheels widened. It wound up being a better deal to just buy a different set of wheels. Probably more worth it with a CTSV since there are so few wheel options, plus the stock ones look pretty good. I can probably dig up the name of the place (in Ohio I think) that quoted me on that. Let me know if you're serious about it. Also not sure how far "inboard" you can go on a V without having clearance issues. Gets a lot more expensive to widen a wheel if they have to cut it apart in two places.
#40
How wide to go
BTW, That pic of the rear set up is perfect.
I had a recent issue (read curb/guardrail) with the rear letting go on my favorite s-curve off ramp and now want to look into this mod.
So let me know if this is correct for running 295's on rear:
1) Have stock rims widened to 9.5 inches (looks like $200 per)
2) Mount 295's on new rims (recommended tire?, grip vs cost?, aspect ratio if running stock fronts)
3) Get 5mm spacers made (cost estimate & who?)
4) Get longer rear wheel studs (cost & where to buy?)
5) Need to roll fenders??
Also, is running stock fronts with 295 rears make sense handling wise ???
It's my daily driver (except winter). I like hooning around on the on-off ramps , I don't drag or track and occasionally drive two hrs on business - i.e. comfort vs performance?
Great discussion, thanks for the info!
BL
BL
