bad shfter...help!!! 2005 cts-v
Basically i can put my car in any of my gears and move my shifter left and right as if it were in nuetral. any ideas? will a short shifter fix my problem? Is it shift linkage? is there a diy that i can do to fix this?!?! im going crazy.
also. it is very difficult getting it in reverse, i pretty much have to force it in.
1st and Reverse can be a bit Tricky. A shifter will help shifting, but Bushings is what you need... Call Luke at Lindsay Cadillac and get the Shifter bushings.
A trick I learned for Reverse is to Put Pressure on the shifter while engaging the clutch, and it pops in...
Thanks for the headsup on the clutch reservoir, ill figure out where that is tomorrow with my friend.
any idea what part numbers i need for the bushings!? i heard they should be around 30 bucks...
thanks again
thanks again
FWIW, the UUC bushings will only improve the feel if you stock bushings are in bad shape. However, if they aren't already in bad shape they will be at some point, and the UUC ones will last forever.
You should really consider a short shifter in combo with the bushings if you really want to tighten things up.
