Need help with Z06 LS7 Slave Cylinder Line Routing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Putting a new LS7 clutch, pressure plate and slave in the V -
Clutch and pressure plate went in smooth, but the steel line on the LS7 slave is longer, and it has a hose attached prior to the connection so that the length is longer than the stock slave.
For those of you that have installed these, how did you make the connection and/or route the lines?
Thanks in advance!!!
The following users liked this post:
stmotorsports (07-06-2023)
If I did it again I'd just buy one of those hand held brake line benders to ensure a uniform bend..
Tick sells a stainless braided line to replace the long line with one of the appropriate length. Personally, I bent mine forward and used the little metal hanger that came with it and attached it to the bell housing to motor bolt right in front of the hole for the line. Then I just ran it up and it was the perfect length. Worked like a champ.
