Check Engine light issue
The CEL came on about a week ago, so I had it checked at Advance Auto and the code read bank 1 performance or something like that. I figuered it was on 02 sensor, but if anyone has any insight it would be greatly appreciated. Thanks in advance.
need more info here bud. was it one of these?
P0130 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1
P0141 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 2
How is you car running?
Car is running fine, no bucking or surging. As far as the actual code number, I didn't get a change to look at the screen, because the guy cleared it out. I turned the ignition off, and it was gone, but it came back the next time I cranked it up.
The codes were P 0340 and 0341, anyone with experience with these codes. Says something like bank 1 perf cam sensor or something like that. Any help is greatly appreciated.
Coincindentally, I just diagnosed a 2000 Maxima with a P0340 code which resulted in a bad camshaft position (CMP) sensor. Replaced the sensor and everything is fine again. Always verify that the wiring is good before buying any parts.
Helps a lot to have the specific code.
Thanks for the replies, and I will definitely check it out. But the funniest thing happenned today while I was driving back from the gym...the light flicked on and then 10 seconds after the car was sitting idle, it turned off and never came back on. Even after I cranked the car up 3 times. Any help with that one? LOL
Almost the same thing here. The car I worked on would stall. After a few minutes it would start and run again. Intermittent.
...replaced the sensor everything works fine now.
Last edited by Slithering_Joe; 06-09-2009 at 05:37 AM. Reason: clarification, car is fixed
