Bmr pinion support
Bmr pinion support
I'm new to the caddy world, and need to know if anyone has used the bmr pinion support and if it works. the caddy has so much slop in the motor mounts and rear, and i'm just trying to make the car feel tight like it should. With no wheel hop. i'm buying some motor mounts already. let me know what you guys have done that works. I'll be porting a set of heads for the car and developing a good cam for it once i get it right. Also what is the best kit to lower the car, i was thinking ground control.
I have a pinion support from BMR, and it reduced it as well. I think you have to upgrade the Differential Bushing to totally take the thump out.
Wheel Hop is another direction. I know their are products out there to alleviate it, but this is my DD, I never take the Traction Control off. I think BMR & Karrs are along the lines of that problem.
My path is going like this...
1. CAGs....Done
2. Motor Mounts/Trans Mount...done
3. BMR Pinion Support....done
4. Spare tire...done
5. Diff Bushing
6. Shifter
1. CAGs....Done
5. Diff Bushing
6. Shifter
