Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
1 7/8 kooks installed :D
Old 10-06-2009, 07:48 AM
L82gofast's Avatar
I have a Innovate motorsports LC-1 I use and also a UEGO I need to find a mounting solution for so I can have it permantly installed in the car.
Maybe a single cup for the dash......
Old 10-09-2009, 10:56 AM
pcf_mark's Avatar
Did you guys put the headers on with the engine/trans in or do you need to lower it? I have been thinking headers but I was not going to pull the cradle assemlby down to do it unitl my clutch pooped out. I have a lift so I can get at everything...
Old 10-09-2009, 01:35 PM
maxspeed96ct's Avatar
Nope you dont need to drop either. I did mine on ramps..
you gotta pull your coil packs, spark plugs, pull of the coolant temp sensor on the driver side.
Old 10-09-2009, 01:48 PM
jerrad's Avatar
Might think about putting motor mounts in at the same time. Might save some work later on.
Old 10-09-2009, 02:37 PM
I wish I did, now i have to do motor mounts ..
I think I can do it without removing the headers..
But your right, should of done then at the same time...
Old 10-13-2009, 02:15 PM
LT4POWR's Avatar
Originally Posted by L82gofast
I believe it is even quieter than the stock manifolds and cats inside the cabin.
Really?...wow, I find that hard to believe.
Old 10-13-2009, 02:39 PM
L82gofast's Avatar
I was pleasantly surprised myself. Keep in mind that I had a Corsa system on it already. Its absolutely louder outside the car (in a good way) but definitely quieter in the cab while cruising.
Old 10-13-2009, 02:46 PM
My car is alot louder after I installed the headers...
I cant see how it can possibly be quieter.
Maybe a diffrent sound but louder..
Old 10-13-2009, 02:53 PM
L82gofast's Avatar
Could be the corsa system. I know when I put headers on my last vette that had a SLP setup on it, it was godawful inside the car. I wound up putting on a set of Z06 mufflers.
Quick Reply: 1 7/8 kooks installed :D
