Lowered Pics, H&R's
#41
#44
right, but that's not what i'm saying. what i'm saying it that the stance isn't all that with these. it still rides high, especially in this pic.
maybe it's just me, but the rear needs to be lowered a bit.
#45
H&R's are not the perfect ride....
Great stance, yes.
I was barely out of my driveway after installing my H&R's and noticed it was way too bouncy on the front. After about 5,000 miles, it's not so bad, but the bounce is still there. I've taken several 2 hour at a time trips with the car and it wasn't too bad. I don't regret using the H&R's regardless of the bounce, I just wish that wasn't there.
Great stance, yes.
#47
#48
This picture tries gives you a better idea of the true stance of the car. This shot was taken at the beginning of threshold braking when the weight is biased forward. The H&Rs do a pretty fair job of keeping the car level. Notice the ride height at the back and the fender gap at the rear.
#49
I have noticed that when the car isnt sitting exactly flat(even) some wheels look tucked, and some sit high. the angle the car is sitting at may make it look like it needs to be lowered but my guess is that it isnt sitting on even gorund its articulating the surface.
#50
that is correct. i sometimes find myself wondering if i adjusted the coil-overs correctly when i see one side is tucking to the rim and the other side tucking some of the tire. it should simply tuck down to the middle of the sidewall portion of the tire al around, but an uneven surface can change all that.
bu, it's certainly the angle, because that other pic looks great.
conservative and classy. nice job.
#52
Yep, kit worked great, only complaint is that it was a lot more work then it looked IMO, removing the upper half of the back seat and stuff, but im sure it would have been different if i hadnt been tired after doing the hendrix axle kit right before lol.
#55
And to make it worse if you have the tan interior you have to wash your hands every 5 minutes so the back seat doesn't look like a hog pen.
#56
#58
i was laying flat on my back all the way inside the trunk with my head smashed up sideways against the rear seats just to get leverage to loosen/tighten the nuts.
have fun. i'm paying next time.
