Gauge Pod on Steering Column Trim
i have seen one before in the center but it blocks to much of the the Gauges IMO.. I got an aeroforce, i poasted the same thing on the other forum but some only use one
This is the first time i'm messing around with fiberglass so take what i say with that in mind!
i have no idea what im doin
Total time building the pod...3hrs.. i took a bunch of beer/sangwich breaks
$15 for supplies is way cheaper then buying a craptasitc pod of ebay and then trying to make it look good
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0763.jpg)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0750.jpg)
So rip off the steering column trim and mask it off
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0730.jpg?t=1269487432)
get some PVC pipe cut it to size .. i just found scraps in the garage.. lay a thin layer of Resin on the masked off surface.. lay some fiberglass mat.. lay some more resin.. place the PVC ... position it. wrap it wit some resin.. work fast it drys quick..
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0733.jpg?t=1269487460)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0734.jpg?t=1269487563)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0735.jpg?t=1269487608)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0732.jpg?t=1269487967)
let it rest for 20.. and then hit it again
front
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0736.jpg?t=1269487608)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0737.jpg?t=1269487667)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0740.jpg?t=1269487709)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0741.jpg?t=1269487709)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0742.jpg?t=1269487818)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0743.jpg?t=1269487869)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0744.jpg?t=1269487943)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0746.jpg?t=1269488054)
i put another screw in as well over to the right about an inch
Its not perfect by any means but it gets the job done..
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0747.jpg)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0748.jpg)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0752.jpg)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0754.jpg)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0759.jpg)
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/installed%20aero/DSCF5451.jpg)
front
![](http://i549.photobucket.com/albums/ii384/shadybx7/aeroforce/IMG_0757.jpg?t=1269528516)
I have been detailing for my boys ( the owners of Glow Shift) and we are currently working on a single steering column guage pod and a dual pod for top or center air vents.... or air vent delete and fill with pods... not too sure yet
Thanks guys... i would make more if i had the steering wheel trim.. Im getting the aeroforce wideband kit so i can hook up a sensor to my SW headers
this the legit Pod you guys are referring to:
![](http://www.cadillacforums.com/forums/attachments/2004-2007-cadillac-cts-v-general/38004d1197074068-dual-gauge-pod-picture-088.jpg)
http://www.summitracing.com/parts/ATM-10001/
I agree its the ****, i was going to get it but i don't have a need for a second gauge with the aeroforce
The jelly resin i was using.. in the first and second picture.. must have bondo in it because it drys unlike any raw fiberglass i have even see..REMEMBER i had no idea what i was doing just going off what i have seen on tv....i could have made it perfect but i just didn't have the patience to sand it all the way down.. if i make another maybe ill pick up some Polyester glazing putty and try it out..
nice, only thing id recommend is using a heavy primer to fill in the little holes. It would really finish it off nice. Other then that is came out really nice. Ill be doing the same in my camaro but hanging off the top of the gauge cluster in the 2 blank spots.
Nice work.
Nice work.
OP - great job on making your own gauge pod!
Looks like that got sanded down a bit to fit the curve above the HVAC vent, right?
