Figured out most of the wheel hop...
I dont see how it could get better if I installed a passenger side axle. Not to mention no one made a passenger side axle and even Hendrix agreed that it wont make much of a difference to have the passenger(econo axle). He simply started making them because some people are **** and want to do both sides. the pro axles are a different story since its not just the bar thats beefed up.
LOL wasnt trying to offend anyone by my post, when I saw that he was making the passenger side I had wondered why since when I talked to him he said only one was necessary. I dont blame anyone for buying two since it doesnt hurt.
Didnt you guys do the pro axles though? or did you just go with gforces?
I was told the 04-05 axles are one diameter, and then the 06-07 axles were also the same diameter as each other but larger then the 04-05 ones.
I paid about $300 for one larger then stock sized G-Force axle. Had the dealership install it for right around $300, reason for using dealership was in case there were any incidents during replacement they'd be responsible. No wheel hop since then, did a huge first and second gear burnout behind the dealership on a back roadway only 50 feet across field from dealership. Video coming later...
I had an option to buy both sides in the harder/hardest usable material, 300M billet steel, but didnt really see the need for something that really wouldn't ever be seen much. (although I almost did buy both axles up until the last moment before ordering... lol)
Very possible IMO. Had this problem on my C5 and it was the shocks. Exact same tires. Afterward it was much better. Does the car feel like it's' finding grooves in the road when you drive?
i have Specter bushings on KDW's and it bunny hops... not full blow thuds and crashes on the subframe like it used to be but chatter..hophophop.. chattter
don't know which axles to get there are to many confusing posts
#32
#33
Whatever axle you get will fix the hop...some of us just have favorites. Just like beer, I'm a Shiner guy.
#35
What year is your V? You measured the diameter of each axle and they are different?
Stock, the length is different but the diameter is the same. GM did not stagger the diameter of the axles on the V until the V2.
If your V has staggered then they are either aftermarket or GM effed up.
#36
#37
My bad.
#39
My GForce axles are very staggered. You can tell just by looking that the shorter side (passenger? I can't remember for sure) is very thick and the longer side is actually thinner than my stock '04-style axles. Pretty crazy huh?
They seem to work exactly as advertised (in other words -- wheelhop is gone). I will have video and a full review in a few weeks.
#40
Anything wrong with just getting a factory unit? ie. One 04-05, and one 06-07.
What are the size differences of the two generation or factory axles?
Anyone have part numbers?
With 80k+ miles on my car I would rather buy a complete new assembly.
