Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Differential girdle construction
Old 10-05-2010, 12:14 PM
  #41
bamacaddy's Avatar
I'll have to say that down here this whole project deserves an ATTABOY.....Keep us updated on your progress
Old 10-08-2010, 11:54 AM
  #42
ColeGraham's Avatar
this x[enter any number you want]
nice work man. i cant wait to see the end result.
Old 10-09-2010, 11:13 AM
  #43
killernoodle's Avatar
I ran into a slight hiccup with the 8.8 project. It looks like we probably won't be able to use the aluminum 8.8 here because I have to cut the mounting wings off to fit the diff between the exhaust. I need to weld an additional bracket on the differential case to get it to a place where I can mount the front pinion.
So, if you know anyone with a junk thunderbird who is getting rid of a steel 8.8 case, let me know! Otherwise, I'll probably be at pull-a-part tomorrow yanking one or two.
Old 10-09-2010, 11:41 AM
  #44
GulfM3's Avatar
Why not just slightly "bow" the exhast around the mounting ears? Seems that modifying the exhaust would be much easier than modifying the diff case.
Old 10-14-2010, 09:33 PM
  #45
serik21's Avatar
any updates??
Old 10-18-2010, 11:19 PM
  #46
Yep, I haven't lost hope. I went to pull-a-part on Sunday and picked up the cast steel 8.8 from the thunderbird. It only took me 30 mins to pull because someone had already dropped the diff and crossmember to get the driveshaft (for whatever reason). I'll probably end up using the cast steel diff in my car as a mule while I work on figuring out the best way to make the aluminum diff possible. It will probably end up needing minor exhaust work to route the exhaust further away from the differential.
For now, I'm going to try welding directly to the steel diff and getting the geometry right for the pinion angle, torque brace, etc.
The steel 8.8 definitely looks/feels stronger than the aluminum 8.8. It is possible this is a better option for our heavy cars anyways.
Old 10-24-2010, 03:51 PM
  #47
Stone17's Avatar
All the Lincoln Mark VIII from 94-98 came with aluminum diff with gear ratio 3.07 or 3.27 (LSC).The thunderbird came with the steel diff.
What half shaft are you using?
Old 10-24-2010, 04:34 PM
  #48
Fuzzy_Wuzzy's Avatar
it is too bad the thunderbird sitting next to my caddy is still in such good shape... and doesn't have a limited slip
Old 10-24-2010, 05:02 PM
  #49
Stone17's Avatar
HAHA.
I'm with you on that but I have a Mark VIII with 4.10 and limited slip.
Old 11-03-2010, 03:42 AM
  #50
serik21's Avatar
any updates??
Old 11-03-2010, 04:48 PM
  #51
DrSpeed's Avatar
Blue Torch Fab makes some cool parts too for fab work.
http://bluetorchfab.com/store/index.php?cPath=104_118
That's just 8.8 stuff. I've got their parts for my D60 in the front of my Superduty.
Old 11-04-2010, 12:08 PM
  #52
Just a couple pics for you guys. I wasn't able to work on it because I ran out of shielding gas. I will go out today and get my tank refilled.
This is the bottom bar of the torque brace that will go forward up to the carrier bearing mount. I haven't ruled out making the mounts solid at the diff and urethane at the end of the torque brace, I just want to figure out which way is best.
Also, I haven't ruled out the possibility of making this mount to the stock location, it would just require notching the crossmember like the 9" kit.
Attached Thumbnails Differential girdle construction-img_20101025_210542.jpg   Differential girdle construction-img_20101025_210559.jpg
Old 11-04-2010, 04:39 PM
  #53
vmapper's Avatar
Doesnt Creative Steel have a Bolt in 8.8 rear for these cars?
Old 11-04-2010, 08:49 PM
  #54
liqidvenom's Avatar
thats the rumor i have heard but i havent seen anything along those lines yet
Old 11-12-2010, 09:38 AM
  #55
lollygagger8's Avatar
Something like this should be explored as well. Seems to be for more strength, but definitely something we need.
Old 11-12-2010, 10:00 AM
  #56
lilgcts-v's Avatar
there already is a diff girdle from TCperformance
Old 11-13-2010, 04:38 PM
  #57
-T-
-T-'s Avatar
How much are they selling them for? I went to their website but didn't find any price information. I seen the YouTube video. Looks sturdy. I just wonder how abusive they have been to really test it out.
Old 11-21-2010, 11:52 PM
  #58
I did a little more work with it today. I decided to nix the bushings at the differential because these are a known weakpoint with the cobras. I'll put the bushing at the end of the torque arm to keep any differential play down. The red is the planned bracing.
Attached Thumbnails Differential girdle construction-img_20101121_235559-large-.jpg   Differential girdle construction-img_20101121_235517-large-.jpg   Differential girdle construction-img_20101121_235456-large-.jpg   Differential girdle construction-img_20101121_235436-large-.jpg
Old 11-22-2010, 12:06 AM
  #59
itsslow98's Avatar
IMO your gonna have to put some sort of bushing in that second picture.
Old 11-22-2010, 12:25 AM
  #60
Nope, I want to keep the arm rigid between the rear cover and the front mounts of the diff. There are already bushings in the rear subframe, the other bushing will go at the very end of the Torque arm.
Quick Reply: Differential girdle construction
